L33 5.3 na performance build recipe
Old 12-05-2013, 02:25 AM
BigEd_72455's Avatar
cobalt, where are you located at?
Old 12-05-2013, 05:39 AM
fieroguru's Avatar
Originally Posted by AlexTVR
I'm building a L33 at the moment
Cleaned up stock heads (799's)
Trick flow titanium ret and spring kit
Comp push rods
Comp lifters
Comp trunnion upgrade
Comp 231/239 lsr cam
Fast 90 with TB
Arp rod bolts
Cold air feed
Free flowing exhaust
Melling hp oil pump
Ls3 front end
Now idea on power, but will post up when it's dyno'ed
That combo should be north of 450 fwhp when tuned. Just make sure to install the cam and the IVC point to get peak HP around 7K. To make good power from small cubes, you need RPM.
Old 12-05-2013, 07:01 AM
Dusty B's Avatar
Originally Posted by Hero
thanks but after I noticed it there you could have just said the top of the page
I wasn't trying to be snarky. Just a playful jab, with a helpful link. Though other fellas might have been interested in that link as well. I sure was!
Old 12-05-2013, 01:47 PM
cobalt964's Avatar
biged im in okc area of Oklahoma. where are you?
Old 12-05-2013, 02:14 PM
rockytopper's Avatar
subbed
Old 06-10-2014, 07:26 PM
smaruska's Avatar
I know this is a little old but subscribing. I've got an ultra clean 98 GT Mustang with a PI swap but building the modular is an exercise in futility and even the cheapest supercharger setup is more $$$ than a 5.3L LSx and trans combo. I know that's not all that is involved but I'd rather build a LSx than a Mod motor. Would for sure be looking for a L33.
Old 06-11-2014, 10:31 AM
2muchboostNY's Avatar
**** man thanks for bumping this old thread....never read this one but some good info here.
Old 06-11-2014, 01:29 PM
speedworxs's Avatar
this may sound like a noob question, but since you were nice enough to list all the parts for this engine build, could you add the parts necessary to do the manual transmission swap
Old 06-11-2014, 02:44 PM
bfurches's Avatar
I guess I will add my experience to this...
Last year I played around with an L33 in my Caprice before I swapped over to the turbo 4.8 deal.
Race weight at the time was 3620lbs
Motor was a BONE STOCK L33 with 140+k miles.
Stock cam, stock rod bolts, stock gaskets, truck intake yada yada.
I literally bolted a f-body pan to it, electric water pump, Dougs f-body shorty headers (1-5.8 primiaries 2.5" collectors) and dropped it in.
Through a th350 with 3.73 rear gears, the car would run 13.0 @ 105 all day long after driving it to the track in 90* weather. The combo definately had a high 12 in it.
I am not big on dyno numbers, but for a BONE stock motor, seemed to do ok.
This is what it looked like last year:
Old 08-29-2014, 03:03 AM
cobalt964's Avatar
I am now building one for my 71 k20 suburban too
Old 08-29-2014, 05:51 AM
bk2life's Avatar
lots of good info here
Old 08-29-2014, 06:25 PM
  #32
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Are L33s Gen III or Gen IV engines?
Andrew
Old 08-29-2014, 10:19 PM
  #33
Jake Spoon's Avatar
Andrew
Gen III
Old 08-29-2014, 11:03 PM
  #34
V8Rumble's Avatar
Talking
Hmmmm. So... I'm guessing a 5.3 might do OK in my brother's Pinto???
Old 08-30-2014, 02:16 AM
  #35
cobalt964's Avatar
l33's are gen3, lh6 is the gen4 variant
Old 08-30-2014, 09:46 AM
  #36
The LH6 was in the Trailblazers...but I don't believe it got the 799 heads.
What about the LH8? Does it have the 799 heads?
Andrew
Old 08-30-2014, 09:39 PM
  #37
cobalt964's Avatar
from GM's website, which is the 799 heads;
The Gen IV Vortec 5300’s cylinder heads have been enhanced for improved performance and efficiency. As a result, the LH6 delivers the horsepower and combustion advantages of a higher compression engine, yet operates at peak output on regular-octane gas.
The LH6 takes its cylinder heads from the LS6 V-8 that powers Cadillac’s high-performance CTS-V sedan. Originally developed for the Corvette Z06, these heads improve airflow in and out of the engine. With their pent-roof combustion chambers and new flat-top pistons (the pistons in Gen III Vortec 5300s have a slight sump in the piston deck), the Gen IV Vortec 5300’s compression ratio increases from 9.5:1 to 9.9:1. This increase improves the engine’s volumetric efficiency and increases horsepower.
also the lh8 in my wifes hummer h3 alpha also has the 799 heads.
Old 08-31-2014, 11:49 AM
  #38
Jake Spoon's Avatar
The LH6 has DoD, correct?
cobalt, any opinion on the difficulty of a Gen III swap vs. a Gen IV swap? It seems like I recall a discussion with Novak where they indicated Gen III swaps were much easier...
I ask because I'm trying to source an engine for a swap and wanted the L33, but there is an LH6 available locally.
Old 08-31-2014, 10:58 PM
  #39
cobalt964's Avatar
lh8's are non dod non vvt and are fine to use. the only difference from l33 to lh8 is the cam position sensor location. if you are doing a swap already it is negligible whether you use l33 or lh8. they are both alu block 5.3's with 243/799 heads, flat top pistons, better rod bolts, etc. the lh6 is dod but non vvt and is easier if you replace the dod lifters and use regular non dod lifters but the lh9 5.3 alu block is a dod vvt and could be used but is more difficult to remove the dod and vvt but not impossible.
Old 10-11-2014, 01:12 PM
  #40
patman7800's Avatar
thank you all for the kind words. I hope my experience can help others too. fieroguru I followed your build on pff, nice build.
How was idle. With the ls2 cam did it have a nice bump in the idle or was it just a smooth stock idle
Quick Reply: L33 5.3 na performance build recipe
