On 3 Performance LS1 swapped Foxbody Kit / Build
#182
#185
Ok I finally got mine going and have about 150 miles on it and already burned two spark plug wires. Any kit owners relocate their coils and if so where did you mount them? Or if you found a solution to make them not burn up?
I had the hot parts ceramic coated, I wrapped the down pipe and even out the spark plug boots...still burned up my new MSD wires.
#186
hey guys, how are these kits holding up long term ?
also any rubbing on that hot side down pipe?
also looks like its needs to be removed to change the plugs, correct?
#187
