possible to use hydroboost out of my mustang
Is it possible to retain the hydroboost brakes and steering when doing my 5.3 turbo swap. I know I can swap over to the v6 mustang brake system I just wondered if I can retain the stock brake set up.
i was just looking into this for my 65- not sure if you already have hydroboost? This was mainly on the cobras right? Yeah if you already have it you can either adapt the stock pump to fit on the ls motor like im doing, or they sell a pressure reducing fitting that screws into the stock ps chev pump and hook everything up as it was. Just takes pressure out to the hydroboost, then from there to the ps rack. Two returns, one from each. Pretty simple system and from the looks of it what ps pump you use doesnt really matter if the pressure is ok. Only thing i saw was the chev uses PS fluid right? and the ford stuff uses atf in the system- and they dont like each other- so if you can use atf in the chev pump that works. Im not doing hydroboost but im making a custom braket to put the ford late model mustang pump onto the LY6 i bought, it uses the same serpentine belt six rib.
my loose setup i did when the new pump arrived- just ordered a stock steel bracket for this pump and i'll cut off when i need then weld that all to some heavy plate that will bolt on where the a/c pump used to go. Then i need some idler pulleys and brackets for the alternator...
actually i was looking more closely at this last night and came up with a different solution- something more like this...
so you can buy a kit for the drivers side alternator to mount everything like this with the idlers- i'll prob make one- but the passenger side im on my own. Hopefully the mount i make for the ps pump has some room and i can mount another idler on there to keep the belt away from the truck thermostat. Maybe after i fab one up i'll give it to my engineer buddy who can scan it and remake them in solidworks and have a shop start making them up- we do that every once in awhile.
