6.0 swap with fbody accessory brackets
Old 03-09-2014, 06:56 PM
Dustytrix's Avatar
Default 6.0 swap with fbody accessory brackets
I am having trouble getting my alternator bracket, idler pully to line up square. I am using a 6.0 block, drilled and tapped for the extra alternater bracket hole in the front left corner of the block. After the 02 camaro alternater quit I upgraded to a tahoe alt. and could not use the back brace that bolts the alt to the side of block. Now I only have 2 bolts holding the alt, and bracket on since the 6.0 block cant be drilled-tapped for the bolt under the idler pulley. How is everyone lining the idler pully up? Mine is cocked towards the radiator, because of the lack of bolts.
Quick Reply: 6.0 swap with fbody accessory brackets
