99+ F-body Wiring Harness Need help with TPS Wires
So I am having trouble with random tps issues that will cause high idle, glowing headers ect..... I did a continuity test on the ground wire from the tps to the pcm and found that I have continuity on several other pins then the wiring diagram indicates.
Can anyone with a 99+ harness sitting on a bench or in a car right now that can run a continuity test on a few wires for me? it would be helpful if the harness is as close to stock as possible.
Red Side #36 (Brown wire)
Blue Side #20 (Orange Wire)
Blue Side #42 (Drk green)
Blue Side #57 (Orange)
Blue Side #60 (Black)
