factory oil pressure sensor needed?
I'm trying to wrap up my 5.3 swap into my 70 Suburban. Does the ECU need the factory oil pressure sensor? The Suburban guage uses a hardline pickup that comes off of the oil cooler bypass. Can I just delete the stock 5.3 sensor behind the intake?
LS1nova,
Mine throws a code for low oil pressure (2005 LS2). Because I have the factory sender removed and replaced with my oil pressure gauge sender.
I have only driven it around the block a few times. Will this code give me problems? So far it doesn't feel like it's running right
