F body P/S pump pulley swap
Thought i would put this info out there for those of you putting ls1's in a 2nd gen camaro. I have a 75 w/f body acc. I found some good info on here about diff pulleys that would work on these pumps but it took me a couple of hours of looking. So i'm putting all in 1 post. I bought a f body pump from a member on here w/o a pulley because i knew i wanted to run a diff pulley anyways, 1 with access holes to the bolts. After looking i found that a gto pulley would work but they are $95 at the local dealersip. After some more looking a member on here had posted that a 2004 pontiac montana 3.4L pulley would work but wasnt sure. I called the local AutoZone and they had 1 in stock for $16.99 (Dorman). I picked it up and pressed it on. Functions good except that 1 of the bolts isnt accessible. It's 1 of the small 13's not the long ones that go through the pump body.
