84' elcamino 5.3 & 4l60e swap
Getting ready to help a friend with his swap. He wants to keep a/c and power steering. Anything out there to keep his a/c any thing to watch put for with this swap?
Just depends on how he is doing the install. Truck FEAD? What motor mounts? Stock coil location? Going to need a a/c bracket or do some fitting to use the stock truck location. Depending on the motor mounts you use ... You might need to clearance the a/c blower housing for coil clearance. You are going to have to research and pick an oil pan. Truck pan hangs mandingo low. cts-v is 1/2-3/4 low. Fbody is tucked above but requires the engine pushed back to the max or cut the crossmember. Thats only some of the things. Good luck!
