69 Camaro LS swap radiator hoses?
I am in the process of swapping in a Griffin LS swap radiator, both hoses on passenger side, in my Camaro. Has anyone used this radiator with off the shelf Dayco hoses? If so what P/N's did you use?Thanks, Tim
Not a '69 Camaro but I used:
Lower radiator hose:
Gates 20450(this has been used by many different swaps) I had to trim both ends but the angles are right on.
Upper radiator hose:
72210 (not sure brand) I had to cut a section out of the middle and put in a 6" coupler from Summit. But again the angles are perfect.
Just did this not to long ago with the same radiator. Might be a few differences but you should be able to use them. I got the upper off of eBay and the lower from autozone. The eBay one is a very big hose but you just cut what you need. Pm me if you have any questions
Upper 22358
Lower B71013
Upper 22358
Lower B71013
