best fitting 64-67 A body swap parts
what is currently considered the best 64-67 GM A body swap kit or engine mount kit? I see a lot of threads from several years ago but just wondering if there have been better versions designed since then. I see Holley has a nice oil pan. I haven't researched headers yet but i'm guessing there are lots of options out there.
Bob
Bob
302-1 Holley pan, hooker engine plates and energy suspension short and wide motor mounts. Doug's headers are the only ones that fit these cars. However, the morons put the o2 bung on the outside of the headers instead of the inside where it belongs. I bought mine uncoated and added bungs on the inside. Check out my build. Most everything is documented. The Holley 302-2 pan offers more clearance but the casting and machining is subpar compared to the 302-1.
Btw...the Flowmaster headers are Doug's headers with a different flange. I had a set in here and prefered the vband clamp over the ball and socket.
Doug's engine plates are ok...but uncoated and have the same location as the hookers. I almost used the dirty dingo mounts but I didn't want the extra height of the mount. You will need to invest in a CV driveshaft.
We'll get around to it as we're quite aware of the popularity of those vehicle vehicles for use as a swap platform. There's a least 7 or 8 additional vehicle applications I can think of that would be worthwhile to build a complete swap system for and that is one of them.
I have the Holley 302-1 oil pan. Headman 1 3/4 to 1 7/8" stepped headers that fit real well. Dirty Dingo sliders with tall and narrow mounts. I am running a 6L80 so we had to raise the transmission tunnel an inch. This is on a 65 Skylark. Looks like Holley will be coming out with a complete kit.
+2 on the flow master headers they are perfect fitting and don't hang low.
See my thread for the parts I used. Only thing I had to fabricate was the trans mount and that's only because I didn't want to buy one.https://ls1tech.com/forums/conversio...el-camino.html
I'm using Doug's headers and adapter plates, 5.25" dorman power steering pulley, Autokraft oil pan. Headers needed a ding on 1 tube to clear the steering shaft, 1 bolt had to be ground down on the steering box, oil pan will need to be dropped and notches welded in to retain full steering. I'm most likely going to sell the pan and go with the Holley 302-2 and improved racing baffle. If the engine were set back another 1/2", the header would clear no problem.
Sorry for the long story.
My tie rod ends barely contact the 302-1 pan. That is in full lock mode, which the car rarely sees anyway.
Most a-body cars are going to have drive line angle issues unless...... you are either hacking up the floor to get the trans high enough or budgeting for a CV driveshaft.
