1996 2wd f150 5.3/nv3500 mustang guys please chime in
I just started by pulling out the old i6 4.9 and 5 speed ford tranny, I have to figure out the motor mounts and transmission mount. I'm going to pull the bed off and make things easier. I'm going to eliminate the front fuel tank, for the rear tank I got a Walbro 255. Does anybody know if I can use the same hydraulic clutch line? The engine I'm putting in is 2008 GEN 4 5.3 LC9, I already have the original harness reworked, I noticed there is nothing coming out of the harness to hook up to the nv3500, how do I wire the nv3500? Can I use my stock speedometer? Is there a 12 volt source under the hood I can tap in to? I would imagine fox body mustangs are very similar.
