AE86 Corolla: 4.8 Cold Start Problem?
Here is what's going on, maybe someone can give me some advice?
I have a GEN IV with a GEN III PCM/Harness 4.8. Since this is probably not an issue with the engine itself, I figured it might fit in the GEN III section better?
Anyways, here is what the motor has:
Relocated LS1 Knock Sensors
Lingenfelter Reluctor Wheel Conversion Box
LS1 Intake, LS1 Fuel Injectors
TSP 224/224 581/581 112LSA Cam
LS1 Harness/VATS Deleted LS1 ECU
I am not using a MAFS.
The motor is in an older corolla, and is having difficulty starting sometimes. It's like it will spit and sputter until it fires. HOWEVER, even if I let it run for 5 seconds and turn it off, it will start perfectly the next time. I am using a switch panel, and it's possible that I'm missing something? It's strange, because when it does run, it runs flawlessly.
Any ideas?
Any ideas?
