thermostat housings
thermostat housings
whats out there for thermostat housings that point out or down rather than right like the lq4
i am swapping a 6l into a 67 chevelle and the truck thermostat housing makes for a very ugily angle to connect the lower hose
anyone with pics of what may be available?
what are others doing for these swaps?
thanks
thanks
Links to few of them in this thread...
https://ls1tech.com/forums/conversio...t-housing.html
http://store.custombuiltmotors.com/e...ng-t-stat.html
http://www.jegs.com/p/JEGS-Performan...37754/10002/-1
http://www.rockauto.com/en/partsearc...4-33939-283018
2010 Camaro L99 6.2 Auto trans waterpump and T-stat outlet / Dayco 71321 hose in a 67 Buick Skylark with the factory radiator. Not the best I'm sure but it works.
I got one of the ones from jegs, mentioned above.
The LS style thermostat, 2004+ I believe, will fit with a little filing and grinding out of the inner radius of the thermostat seat on the housing. That way, you maintain the heater control valve function of the ls water pump.
I tried the Windstar housing, but couldn't get it to seal the way I'd like.
