Corvette style filter / regulator question
Not a tahoe swap, but on my bimmer I went with Dorman barb fittings and SAE R9 rated fuel injection hoses with fuel hose clamps. For the filter/regulator feed line I bent and flared new 3/8" tubing.
See below
AFAIK fuel pressure on a TBI engine is much less than a EFI and your factory hoses are probably 30R7-rated (or equivalent) which has a max rating of 50psi. You might wanna upgrade your lines to R9-spec.
See below
