Fox Body Cold Air Intake
1987 Mustang Fox Body with LQ9 swap. I need to come up with a better air
intake system. What we have now is feeding 125 degree air into the throttle body. See Pic. Looking for ideas and / or kits that might be out there for this application. Any ideas or pics would be appreciated.
Thanks.
Thanks.
I was unaware on where the factory intake was on these cars. After researching online,
it appears the factory intake was routed to the passenger side inner fender. I guess what was throwing me is there is no hole or opening in that area on this car. Probably is the best option, but I will need to cut a hole to get the air filter outside of the engine bay.
You could do something like this. Get the 4" boot from Spectre and make a clean cover for inside the core support to cover up all the unsightly holes etc.. run your air cleaner outside of your engine room to avoid higher intake temps.
