Removal of hydro steering return on PS pump
Hi all, I'd just like to say thanks in advance.
My power steering pump is taking up some precious space. I removed my steering box, and I THINK the hydroboost return is ruining my install here.
1) is that the hydroboost return?
and if so,
2) what is the best way to plug off flush? can i cut it off, drill it out and then plug from the inside and epoxy in? Or just try and source a pump from a non- hydroboost vehicle?
and if so,
stick a piece of 1/4" rod into it, and then pry it up towards the steering pump. It will bend. Then cap it. Or if you really want to seal it right, weld it. But I strongly suggest trying to make the complete system a hydroboost system. I will never drive another classic without doing hydroboost.
