Ls2 or lq9 for OBS truck 1995
Hi guys, I'm new in this world but I've read so much in this forum it teaches me alot of things, thank you ppl
Guys I really want some power my goal is to hit 450rwhp N/A and the drivability is so important to me.
I heard a lot of guys said that I should go with lq9/lq4 it's a common swap, likes the power and strong as hell
On the other hands, they told me ls2 engine is great engine, they showed me dyno numbers, and I think there will be zero issues for 450rwhp
I know it's a Truck but a 2wd truck, 1500, 5 speed manual,3.73 limited slip rear end and I don't like to tow. I want a street monster
So my question is
Should I go with ls2 or lq9 ?
What would be the easier way to 450rwhp with less mods ?
And what would be the easier swap for me ?
Thank you guys
So my question is
Thank you guys
So my question is
Thank you guys
So my question is
Thank you guys
It would be no problem getting 450 out of anyone of those engines. There both 6.0's but the ls2 is an aluminum block so that would save you weight. You could probably get a lq4/lq9 cheaper than a ls2. If you get a lq4 just make sure you get a 2001 or newer if you plan on keeping the 5 speed, there is a removable shim on the rear of the crank that's not removable on the 99,2000. The flywheel will not line up with the shim on the crank.
So what do you think ? Can I get that 450rwhp of lq9 engine N/A for simple mods ? Truck? Dd?
I know your primary question is regarding RWHP but I'll but if cost is a consideration, I'll offer this; often times, people will suggest getting a truck engine on the cheap for their swap project. But when truck engines are going into cars, typically, the intake will be too tall and the oil pan too deep requiring additional cost in sourcing a car intake, TB, fuel rails, injectors, water pump, accessory brackets, oil pan, etc. etc. Depending on how you go about this, the cost benefit of buying a truck engine can quickly be lost vs. sourcing a dropout from an F-Body or 2004-2006 GTO.
But in your case, you're swapping this into a truck which has plenty of room for a truck intake, oil pan and front end accessory drive. And those tall truck intake manifolds, though ugly in the opinion of some, have been proven to be one of the best performing stock LS intakes.
If you find a good deal on an LQ4/LQ9, I think you can get close to your RWHP goals and be money ahead, vs. sourcing an LS2.
Tipsy
Tipsy
Tipsy
Tipsy
So I think you meant that if I had a car it's just better to get an ls2 rather than an lq9 because it will cost me more
And I should stick with lq9 option because it's better than ls2
I have plenty of room to put both engines in my truck yes ?
So why did you prefer to stick with lq9 while the ls2 has 400hp from the factory ? Because it's cheap yah ?
I don't know man maybe I'm wrong but I think the ls2 will reach me faster to my goal with less mods and still driving it as a daily truck because of the400hp from the factory
What do you think?
The LS2 will have 243/799 HEADS. Aluminum block and if you get a TBSS the good intake, CNC the heads, a good set of valves and springs, a good cam from Scoggin-Dickey and you are close to 500 hp and gobs of torque....
I wouldn't say an LQ9 is better than an LS2. But they typically cost less. The LS2 is an aluminum block with 243 heads. The LQ9 is an iron block but is the same displacement as the LS2 with lower compression (LS2 10.9:1 vs. LQ9 10.1:1).
I would assume a truck engine would fit in your truck without needing to change the intake, oil pan or front end accessory drive. I'm sure with a little searching, you can find similar swaps online and confirm this.
Tipsy
