Intermittent Low Idle, Stalling
Old 06-20-2017, 07:56 AM
leblanc1's Avatar
Originally Posted by Michael Yount
Have you tried to pull codes?
I have not, but I will this afternoon.
Old 06-20-2017, 08:25 AM
leblanc1's Avatar
Another thing that just dawned on me. I have a Walbro 400 in the tank, inline filter/regulator, then fuel rail.
My pressure at the rail is about 50-55psi when the key is in the on position and the fuel pump primes the system. When the car is running, the gauge is pegged out at 100psi.
Is this not another indication that my regulator is failing since I thought it was supposed to regulate at about 58psi to the fuel system?
Old 06-20-2017, 05:22 PM
Michael Yount's Avatar
Shouldn't be any difference in pressure between prime and run. Mechanical gauge?
Old 06-20-2017, 06:58 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
People have reported issues with the Corvette filter/regulator when used with high flow pumps. Perhaps it was fine for a while and then went caput? Maybe swap it out for a new AC Delco part? Seems cheap enough...
Andrew
Old 06-20-2017, 08:45 PM
ls1nova71's Avatar
Andrew
I agree, sounds like the regulator is crapping out. Get a new one, a good brand, AC Delco or Wix and see what that does for you.
Old 06-21-2017, 09:29 PM
leblanc1's Avatar
I replaced the filter regulator with a Wix part. Still have the RPM flux every time I go into neutral from driving.
But..now, there's a power cut when I'm under acceleration. If I get on the gas, the engine kicks back on power bad then revs up a bit and kicks back again then goes. It's never done this before.
Now I'm wondering if the Walbro 400 pump is crapped out.
I don't have a MAF by the way, it's density tune.
Thoughts?
Old 06-21-2017, 09:34 PM
My thought is you need a fuel pressure gauge inside the car to monitor what is happening.
Andrew
Old 06-22-2017, 05:37 AM
leblanc1's Avatar
Andrew
Yeah, that seems to be the next best step.
Old 06-22-2017, 05:42 AM
leblanc1's Avatar
Any suggestions on a gauge?
Old 06-22-2017, 12:38 PM
leblanc1's Avatar
Regardless if I have a fuel gauge though....it appears I have a fuel delivery problem...right?
Old 06-22-2017, 12:57 PM
I just read through the thread again....I don't think what's happened so far points necessarily to a fuel system problem. Mind you - I don't know what's wrong, but there are lots of other issues that could cause the symptoms you're having with the fuel system working just fine. If pressures are indeed varying while driving (...and you don't know that for certain...), why wouldn't the system throw codes as it's trying and failing to run properly and maintain appropriate a/f mixtures? The vast majority of the time, my experience has been that electric fuel pumps either work or they don't. I've never experienced any intermittent issues with them (I'm sure others have...). When stuff comes and goes, it's usually an electrical issue of some sort.
Old 06-22-2017, 04:41 PM
  #32
leblanc1's Avatar
If you watch the video, you'll see that my fuel pressure is at 58 psi pretty solid. I slowly rev the engine at first and things are fine. Then at :28 seconds, I punch it and you an hear the super charger wind down then bang, it backfires. If I punch the gas, the engine starves...but fuel pressure stays solid....why? No CEL and no background codes on computer.
What do I need to look at next?
Old 06-22-2017, 05:04 PM
  #33
leblanc1's Avatar
I agree with your thinking.
And I think the video I posted is fairly indicative of a properly functioning fuel system...at least up to the fuel rail. What's happening with the injectors or air fuel ratio and the computer is still to be determined.
Old 06-22-2017, 07:46 PM
  #34
leblanc1's Avatar
Any chance this could possibly be a TPS or an IAC issue? And if so...how what's the best way to eliminate those as issues?
Old 06-22-2017, 08:34 PM
  #35
If it were - shouldn't it be throwing a code? Given the lack of throttle response and intake backfiring - sounds like a timing issue. That would point to sensor or harness or ground or ecu issues....AND I'd think a code. Mystery.
Old 06-22-2017, 08:51 PM
  #36
leblanc1's Avatar
Not a single damn code.
Old 06-22-2017, 08:53 PM
  #37
leblanc1's Avatar
What is my engine doing?!
Old 06-22-2017, 08:59 PM
  #38
Well, the right amount of fuel, air and spark at the right time does the trick. No reason to think it's not getting fuel. The throttle is opening -- it's getting air. That's what leads me to think it's not getting spark at the right time.
Old 06-22-2017, 09:06 PM
  #39
leblanc1's Avatar
At the suggestion of my father, I pulled the plug from the throttle body and started the car. It ran like crap...kept wanting to stall but kept itself alive. Ran for about 20 seconds. Plugged the throttle body back in and started it up and for about 30 seconds or so, it seemed like the symptoms were gone. I was able to rev the engine with no hesitation and good power....then the symptoms kicked in again. I did get the CEL for TP circuit A and B high and low (P0122 and P0223) but figured they were only caused because I pulled the throttle body connector.
Confused.
Old 06-23-2017, 05:55 PM
  #40
leblanc1's Avatar
Butterfly operation
Quick Reply: Intermittent Low Idle, Stalling
