Anyone using a stock ls1 fbody engine harness for their swap?
Anyone use a stock uncut or reworked 99+ ls1 car / camaro / fbody engine harness for their swap? Just slap it on and give power and ground where needed? Just seeing what exact wires need power and ground to make the harness work so we can fire this engine off with this stock harness, then well see about wiring fuses etc into it. There are 5 external connectors/plugs with wires. I know I can read up lt1swap and research each wire but if anyone knew exactly off the top of their head.
Thanks 64ss, when I was reading and looking and re looking at the harness, it did seem that simple. I'll hook it up, do a simple wiring for it and try to fire it up to make sure the harness is still good. Then delete what's not needed on the harness. Again thank you
