Jarhead's 1965 F85 with LS3 swap
An update, new part continue to arrive. New rings, bearings, gaskets etc. Bringing the engine back to a stock LS3 except for the LS7 camshaft and carb setup and MSD6014.
I think the motor will be reliable, powerful (450HP or so) with a smooth idle and plenty fast for an old fart like me to play with. I think in my Cutlass that motor will easily outrun new Z28s! I guess we will see. I also plan to run the car with a dual plane intake to see how it works vs the single plane.
Jarhead
Jarhead
Yes I was very lucky to have scored that long block for $1500. Supposedly it had " needed rod bearings or something". I looked it over and took a chance. Tore it down to find just normal wear. New rings, bearings, gaskets and the new cam and lifters and it should be good to go. This is the first all aluminum LS I have ever seen apart. I was pleasantly surprised to see really slick looking castings, much nicer than I thought. Aren't modern engines great, even with a carb this LS3 will put out like a big block and weigh less than a small block. Such a deal.
Jarhead
Jarhead
This is Rocky Topper's 65 LS1 Cutlass note the gauges, that aluminum panel and gauges look great in my opinion, much better than the factory setup. I bought this insert from Rocky when he was building his car and it will go in mine. Hope mine turns out as nice.
On Rocky's dash he has LS1 cut into the dash insert before the F85 and Olds insignia. On mine I had him omit the LS1 and I plan to add a couple more gauges than Rocky has. Fuel pressure and oil temp will be the add on gauges. I am looking for an original Olds 442 console (they also used them on various other Olds like the Starfire) and I might have the factory vacuum gauge there as I always liked the look. I do have the clutch pedal setup and I might even try a 6 speed. For sure I'm going to start with the T400 but I also have a Power glide with a street convertor I would like to try against the T400. Lots of ideas for down the road. I have the entire interior new, all the rubbers for the glass and just about everything else to put it back together. We are heading to our other home in Sonoma at the end of this month but the work on the car will continue here in central Texas while I'm gone. It won't be finished soon but it should be a fun, rare car.
#33
Great to hear that another F85 is being rebuilt, swapped with an LS. You are the second person that has a 65 F85 doing an LS swap that has contacted me. Along with Rocky Topper that would make 4 65 F85s, not bad for a rare car. I saw that you have a Camaro drop top, so do I but mine is a lot tamer than yours. I have a 95 Z28 with 383 LT1 and automatic that I keep and drive in Sonoma when we are there. Can you post some pictures of your F85?
Jarhead
Jarhead
#34
I don't have many pictures, I don't think I even have any of the whole car, just a few pics of where I put the 98 f-body brakes on it, the Jeep GC steering box and front suspension upgrades, and a couple pics of the body damage that I was showing to a guy who does sheet metal work. I'm currently deployed so I cant take new pics at the moment, but I'll post what I have soon.
#40
You can see here the dash insert is 2 pieces. Countersunk screws in the lower plate hold it to the dash and the top plate is glued to the lower plate. You can paint the lower plate where the logo is to make it contrast.
Yes a parts car is nice to have. I could help you out with some pieces that I don't need but you really should find another whole car, use two to build one.
