Back-up lights
Back-up lights
Does anyone have a good solution to triggering the back-up lights on a 2014 L83/6l80 swap with no BCM. I tried X2-23 but just get 12V with the key on no matter what gear It's in. Was not too excited about adding a micro switch to the shifter but if there is no other way I may have to.
I had posted this in the Gen V section but then realized that there's not much activity over there.
Any suggestions for people with 4l80e transmissions? The relays on the website was for 6 speeds I think. I have a lokar shifter which works for neutral safety or reverse only, not both. I have it running the neutral safety for the ecm for my swap and need help figuring out another way to run the reverse lights.
