trans wont shift
trans wont shift
I did an 5.3 swap with 4l60 trans I used the factory harness from the 5.3 an everything runs fie but the trans wont shift I can manuly shift it but wont shift by itself its an brand new trans its from a 2002 Tahoe I have power on the trans plug
Is the tire size and gear ratio set properly in the tune? Also the shift speeds? If you have a scan tool you can monitor the commanded gear and see if the pcm is commanding the shifts.
