Help A Newbie Out
Help A Newbie Out
Hey guys a have a 92 chevy camaro rs with the 305 motor fuel injected (auto trans but i recently bought a 5.3 motor that i wanted to swap into this beautiful car but ive never done and motor swaps before and have qustions on parts that would work well with thia motor or even any internals that i can pull from my 5.0 to the 5.3 before i start the tear down can anyone help?
The LS 5.3 and the 305 have nothing in common. Did you get the computer and wiring with the engine? Accessories like the alternator, P/S pump, and A/C pump all still attached to the engine?
Check out Holley for swap parts like engine and trans mounts, headers, etc.
About 10 years ago I helped a buddy put a put a LS1/4L60E into his son's 1989 Camaro. Google Josh Kunkel LS swap. He used Sphon? motor mount adapters. 2000 Fbody FEA. Spear Tech engine bay harness and LS computer and harness. Spear Tech can rework the engine bay harness to retain the AC and other functions.
As said above nothing from the small block or transmission will interchange with the LS.
About 10 years ago I helped a buddy put a put a LS1/4L60E into his son's 1989 Camaro. Google Josh Kunkel LS swap. He used Spohn motor mount adapters. 2000 Fbody FEA. Spear Tech engine bay harness and LS computer and harness. Spear Tech can rework the engine bay harness to retain the AC and other functions.
It's a super easy swap. Did one in my 87. Used fbody accessories and pan. Summit swap mounts and speed engineering headers. Theres a butt load of info over on thirdgen.org. Chances are you'll find way more info over there since it pertains to just thirdgen fbody cars.
