Which parts for f body pan swap on 5.3
I recently tried to buy a half body oil pan, pick up, and windage tray from a member but got screwed over when he only sent a few of the parts and then went silent. I'm trying to figure out what else I need to complete my set up
I know I need an F body pain to work with my chassis set up. The engine is a 2006 L33 5.3. I already have the pan and gasket. I know I need the F body pick up, but should I reuse and modify the 5.3 windage tray or get an F body windage tray? I assume I also need an f body dipstick. Is that correct? Anything else I might need? Thanks in advance for any help or advice!
Explain the language used here. RE: windage tray- You may use the 5.3 one but it might need a bit of modding.
Man, AutoCorrect really jammed me up today ha ha.
F body pan to fit the chassis that my 2006 5.3 Is going into. I already have a pan, drain plug,a gasket, and an oil sender for the pan. I should be able to reuse the bolts from the current truck pan.
