vintage air with factory PCM
Is it worth the effort of trying to re-wire the aftermarket Vintage Air system into my PCM so that the PCM can alter the idle speed as needed? Any ideas advantages, disadvantages, etc?
9 Second Club/LS1TECH Sponsor
Re: vintage air with factory PCM
I've found it's really not worth the effort. The engine runs so well that it doesn't lug it down much at all when the A/C comes on. So instead of the PCM anticipating the A/C coming on by raising the idle just before the compressor kicks on, the engine just reacts to the slight increase in load, and the idle returns to normal that way.
As long as you take care of the wiring so that the fan comes on with the A/C to avoid any head pressure problems, you'll be fine.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
