Removing Transmission Cooler Lines
On a 4L60E, the repair manual states "simply unsnap the plastic collar from the quick connect fitting, then pry off the quick connect fitting retaining clip and remove the lines".
Does anyone have a pic of the retaining clip .
I certainly don't want to bugger up this connection .
Thanks to all who sent pm giving me advice on removal of the clips on the cooler lines.
Here's a pic of a clip that I have half way removed from the cooler line. I bought the tool in the picture from Harbor Freight that comes in a set of four with different tip configuration. I forgot what the tool set is called but cost less than $5. Hope this helps others .
