Fuel Line near miss
Old 04-26-2012, 12:27 PM
68BBChevelle's Avatar
Originally Posted by 67RSCamaroVette
I'm gonna revive this ancient thread because it pops up alot in search results. The new, updated fitting has a thread-on retainer, rather than a plastic squeeze-clip.
__________________________________________________ ______________ (blue)___(black)
-6 AN Male to 5/16" SAE Quick-Disconnect Female with threaded retaining cap..... 644110....644113
-6 AN Male to 3/8" SAE Quick-Disconnect Female with threaded retaining cap....... 644120....644123
-8AN Male to 3/8" SAE Quick-Disconnect Female with threaded retaining cap........ 644130....644133
ive used these and had goodluck so far.
Old 05-01-2015, 06:38 AM
Ollie8974's Avatar
Up dating this thread again,
This is a link to Summit listing all the Russell push on fittings with the threaded
lock collar.
Note the color and size.
http://www.summitracing.com/search?S...EFI%20fittings
Old 05-01-2015, 12:23 PM
Restricted User
JoeNova's Avatar
lock collar.
Those are the exact same ones that were listed in 2012 when this thread was brought back from the dead the first time.
Old 05-01-2015, 01:36 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Earl's also makes an excellent fitting for the stock rail:
https://www.holley.com/products/plum...ts/AT991966ERL
It has steel retainers and a secondary retainer clip.
Andrew
Old 05-01-2015, 03:26 PM
Bowtie316's Avatar
Andrew
I hadn't seen these, I'm sending the russel adapters I just got, back. Thanks for more useful info Project GatTagO!
On second thought, maybe not, it doesn't look like the one for the 5/16 line is available yet.
Earl's Part numbers
Part No. Description
991965ERL -6 to 5/16” QUICK CONNECT Fuel Fitting
991966ERL -6 to 3/8” QUICK CONNECT Fuel Fitting
991985ERL -8 to 5/16” QUICK CONNECT Fuel Fitting
991986ERL -8 to 3/8” QUICK CONNECT Fuel Fitting
AT991965ERL Ano-Tuff -6 to 5/16” QUICK CONNECT Fuel Fitting
AT991966ERL Ano-Tuff -6 to 3/8” QUICK CONNECT Fuel Fitting
AT991985ERL Ano-Tuff -8 to 5/16” QUICK CONNECT Fuel Fitting
AT991986ERL Ano-Tuff -8 to 3/8” QUICK CONNECT Fuel Fitting
Old 05-01-2015, 04:48 PM
Earl's Part numbers
You're right, there is no matching fitting to use for the return side (5/16") of a Corvette regulator/filter, but you can still use it on the feed and on the rail, which are 3/8".
Andrew
Old 05-04-2015, 06:40 PM
Motown 454's Avatar
That Russel fitting is the one I'm using on my CTS V fuel module in my Camaro. Nice piece, its the one connected right to the fuel module.
I wish the pictures were better
Quick Reply: Fuel Line near miss
