pictures of my LS1 swap into 1967 nova SS
#82
its alive hahahaha
http://www.youtube.com/watch?v=WjG-EwjfsIc
STILL NEED TO HAVE VATS TAKEN OUT AND DYNO
but its alive
but its alive
#83
pretty cool-i just got Verizon Fios, got rid of slow dial up, so first time i could look at all the post, lol-great job
where did you get the power steering valve-does it cut pressure to the rack?
im using the vette acces dr in my chevelle, would like to cut the pressure a little
#84
Yeah got it from a hot rod shop. Tim's hot rods. ( 509-926-1429 ). I don't remember how much it was. It was a kit, came with the hose and fittings. Hope this helps
#85
well the car is a dream to drive. really have not done anything. got the covers in today for the coils. looks great i think.
could not pass up the deal for the covers....cheap
#86
Looks sweet. This style of Nova is the BEST !!! IMO
#87
well i hate to say this guys, but my project is back up on blocks. i have an oil leak thats kicking my ***. really dont know where its gonna go from here as for as the project goes. i have oil leaking from the back of the motor again. it seems like it is leaking more now that i changed the oil pan gasket and the rear main seal. so iam gonna pull the trans again and see if i can see were its coming from. knowing my luck, i will have to pull the motor for some god knows reason... i just dont know. iam so ready to move on to the suspenion work and not a dumb *** oil leak
#90
Some Advise is to make or buy a cold air intake set-up. The MAF register IAT temps and with the Air cleaner right behind the radiator the motor will always be pulling timing because of higher intake air temps.
Get the air inlet away from the backside of radiator.
We moved my intake an picked up 20 + horse and the IAT are now under 80 degrees and were over 120 degrees with pulling in radiator hot air.
Hope this helps you out.
Real Nice build.
2001-2004 Chevy Pickup 4.8 thru 6.0 have a small clean looking intake set-up. Might work for your application.
Ralph
Real Nice build.
Ralph
#94
I dig the pro touring look but in your case I also like the way you have it now. I have been considering those style wheels on my cutlass but the problem is I can't find the right offset to fit my car with out having to spend big bucks on custom made wheels.
#95
well starting back up on the motor. have a oil leak that i have been putting off. installed a 4 link in the car and had the rear end narrowed. pulling the trans this weekend to try and find were this oil leak is coming from. major oil leak. but anyways heres what i have done with the car
everything is done with the rear end now. so back to the leak
#97
f**kn awesome build dude.
i just wrecked my 99zm6 and i might have a chance to get a 63 in good condition for cheap to do the swap. whered u get those link and ph brackets?what motor mounts did u end up using?how hard was the wiring with aftermarket gauges?
