I need pinouts for a 99 or 2000 LM7
Connector Part Information
• PCM Connector C1 Assembly 12191489
• TPA (BLU) 12176408
• Connector Cover 12191108
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
PCM Ground
2
LT GRN
1867
Crankshaft Position Sensor B+ Supply
3
PNK/BLK
1746
Injector 3 Control
4
LT GRN/BLK
1745
Injector 2 Control
5-10
Not Used
11
LT BLU
1876
Knock Sensor Signal Rear
12
DK BLU/WHT
1869
Crankshaft Position Sensor Signal
13-16
Not Used
17
DK BLU
1225
Transmission Range Signal B
18
RED
1226
Transmission Range Signal C
19
PNK
439
PCM Ignition Supply
20
ORN
440
PCM Battery Supply
21
YEL/BLK
1868
Crankshaft Position Sensor Ground
22
Not Used
23
PPL
719
Sensor Ground
24
Not Used
25
TAN
1671
HO2S Signal Low Bank 2 Sensor 2
26
TAN
1667
HO2S Signal Low Bank 2 Sensor 1
27
Not Used
28
TAN/WHT
1669
HO2S Signal Low Bank 1 Sensor 2
29
TAN/WHT
1653
HO2S Signal Low Bank 1 Sensor 1
30
LT GRN
1478
Engine Coolant Level Switch
31
Not Used
32
BLK/WHT
771
PRND A Input
33
PPL
420
TCC Brake Switch
34
WHT
776
PRND P Input
35
GRA
48
Clutch Switch Signal
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38-39
Not Used
40
BLK/WHT
451
PCM Ground
41
BLK
407
Sensor Ground
42
Not Used
43
RED/BLK
877
Injector 7 Control
44
LT BLU/BLK
844
Injector 4 Control
45
GRA
474
Fuel Tank Pressure Sensor 5V Reference
46
GRA
416
TP Sensor 5V Reference
47
GRA
597
MAP Sensor 5V Reference
48
GRA
596
EGR Pintle Position Sensor 5V Reference
49-50
Not Used
51
DK BLU
496
Knock Sensor Signal Front
52
Not Used
53
BLK
470
Fuel Tank Pressure Sensor Ground
54
BLK
452
TP Sensor Ground
55
BRN
1456
EGR Pintle Position Sensor Signal
56
Not Used
57
ORN
440
PCM Battery Supply
58
DK GRN
1049
Serial Data
59
YEL
710
Serial Data
60
ORN/BLK
469
MAP Sensor Ground
61
PNK/BLK
632
CMP Sensor Ground
62
Not Used
63
GRA
720
Engine Coolant Temperature (ECT) Sensor Ground
64
Not Used
65
PPL
1670
HO2S Signal High Bank 2 Sensor 2
66
PPL
1666
HO2S Signal High Bank 2 Sensor 1
67
Not Used
68
PPL/WHT
1668
HO2S Signal High Bank 1 Sensor 2
69
PPL/WHT
1665
HO2S Signal High Bank 1 Sensor 1
70
BRN
1174
Low Oil Level Switch
71
Not Used
72
YEL
772
PRND B Input
73
BRN/WHT
633
Camshaft Position (CMP) Sensor Signal
74
YEL
410
Engine Coolant Temperature (ECT) Sensor Signal
75
PNK
1020
PCM Ignition Supply
76
BLK/WHT
845
Injector 5 Control
77
DK BLU/WHT
878
Injector 8 Control
78
Not Used
79
WHT
687
3-2 Shift Solenoid Control
80
ORN/BLK
510
Fuel Level Sensor Ground
• PCM Connector C2 Assembly 12191488
• TPA (RED) 12176410
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
PCM Ground
2
BRN
418
TCC Control Solenoid
3-5
Not Used
6
RED/BLK
1228
Transmission Fluid Pressure Control Solenoid High
7
RED
1676
EGR Solenoid Supply
8
LT BLU/WHT
1229
Transmission Fluid Pressure Control Solenoid Low
9
DK GRN/WHT
465
Fuel Pump Relay Control
10
WHT
121
Engine Speed (Tach) Output Signal
11
DK BLU
604
Secondary A/C High Pressure Switch
12
Not Used
13
LT BLU/BLK
396
Cruise Control Engage Signal
14
Not Used
15
BRN
25
Generator L Terminal
16
GRA/BLK
1694
4 Wheel Drive Switch Signal Low
17
DK GRN/WHT
762
A/C Request Signal
18
Not Used
19
BLK/WHT
1695
4 Wheel Drive Front Axle Switch
20
LT GRN/BLK
822
Vehicle Speed Sensor (VSS) Reference Low
21
PPL/WHT
821
Vehicle Speed Sensor (VSS) Signal
22
RED/BLK
1230
Vehicle Speed Sensor (VSS) Signal (6.0L Only)
23
DK BLU/WHT
1231
Vehicle Speed Sensor (VSS) Reference Low (6.0L Only)
24
DK BLU
417
TP Sensor Signal
25
TAN
472
IAT Sensor Signal
26
PPL
2121
Ignition Control 1
27
RED
2127
Ignition Control 7
28
LT BLU/WHT
2126
Ignition Control 6
29
DK GRN/WHT
2124
Ignition Control 4
30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
DK GRN
1614
HVAC Recirculation Door Control
34
DK GRN/WHT
428
EVAP Canister Purge Solenoid Control
35
Not Used
36
BRN
436
AIR Pump Relay Control (w/NC1)
37-38
Not Used
39
RED
631
CMP Sensor B+ Supply
40
BLK/WHT
451
PCM Ground
41
WHT
257
EGR Solenoid Ground
42
TAN/BLK
422
TCC Enable Circuit (4L60-E only)
43
DK GRN/WHT
459
A/C Clutch Relay Control
44
Not Used
45
WHT
1310
EVAP Canister Vent Valve Control
46
BRN/WHT
419
Malfunction Indicator Lamp (MIL) Control
47
YEL/BLK
1223
Transmission Shift Solenoid B
48
LT GRN
1222
Transmission Shift Solenoid A
49
YEL/BLK
1827
Vehicle Speed Output Circuit 128K
50
DK GRN/WHT
817
Vehicle Speed Output Circuit 4K
51
YEL/BLK
1227
Transmission Temperature Sensor Signal
52-53
Not Used
54
PPL
1589
Fuel Level Sensor Signal
55
DK GRN
603
A/C Compressor Cycling Switch Signal
56
Not Used
57
BLK
552
IAT Sensor Ground
58-59
Not Used
60
BRN
2129
Ignition Control Reference Low Bank 1
61
BRN/WHT
2130
Ignition Control Reference Low Bank 2
62
GRA
773
PRND C
63
PNK
1224
Transmission Range Signal A
64
DK GRN
890
Fuel Tank Pressure Sensor Signal
65
Not Used
66
PPL/WHT
2128
Ignition Control 8
67
RED/WHT
2122
Ignition Control 2
68
DK GRN
2125
Ignition Control 5
69
LT BLU
2123
Ignition Control 3
70-75
Not Used
76
LT GRN/WHT
1749
IAC Coil B High
77
LT GRN/BLK
444
IAC Coil B Low
78
LT BLU/BLK
1748
IAC Coil A Low
79
LT BLU/WHT
1747
IAC Coil A High
80
Not Used
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
PCM Ground
2
LT GRN
1867
3
PNK/BLK
1746
Injector 3 Control
4
LT GRN/BLK
1745
Injector 2 Control
5-10
Not Used
11
LT BLU
1876
12
DK BLU/WHT
1869
13-16
Not Used
17
DK BLU
1225
18
RED
1226
19
PNK
439
PCM Ignition Supply
20
ORN
440
PCM Battery Supply
21
YEL/BLK
1868
22
Not Used
23
PPL
719
Sensor Ground
24
Not Used
25
TAN
1671
26
TAN
1667
27
Not Used
28
TAN/WHT
1669
29
TAN/WHT
1653
30
LT GRN
1478
31
Not Used
32
BLK/WHT
771
PRND A Input
33
PPL
420
TCC Brake Switch
34
WHT
776
PRND P Input
35
GRA
48
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38-39
Not Used
40
BLK/WHT
451
PCM Ground
41
BLK
407
Sensor Ground
42
Not Used
43
RED/BLK
877
Injector 7 Control
44
LT BLU/BLK
844
Injector 4 Control
45
GRA
474
46
GRA
416
47
GRA
597
48
GRA
596
49-50
Not Used
51
DK BLU
496
52
Not Used
53
BLK
470
54
BLK
452
TP Sensor Ground
55
BRN
1456
56
Not Used
57
ORN
440
PCM Battery Supply
58
DK GRN
1049
Serial Data
59
YEL
710
Serial Data
60
ORN/BLK
469
MAP Sensor Ground
61
PNK/BLK
632
CMP Sensor Ground
62
Not Used
63
GRA
720
64
Not Used
65
PPL
1670
66
PPL
1666
67
Not Used
68
PPL/WHT
1668
69
PPL/WHT
1665
70
BRN
1174
71
Not Used
72
YEL
772
PRND B Input
73
BRN/WHT
633
74
YEL
410
75
PNK
1020
PCM Ignition Supply
76
BLK/WHT
845
Injector 5 Control
77
DK BLU/WHT
878
Injector 8 Control
78
Not Used
79
WHT
687
80
ORN/BLK
510
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
PCM Ground
2
BRN
418
3-5
Not Used
6
RED/BLK
1228
7
RED
1676
EGR Solenoid Supply
8
LT BLU/WHT
1229
9
DK GRN/WHT
465
10
WHT
121
11
DK BLU
604
12
Not Used
13
LT BLU/BLK
396
14
Not Used
15
BRN
25
16
GRA/BLK
1694
17
DK GRN/WHT
762
A/C Request Signal
18
Not Used
19
BLK/WHT
1695
20
LT GRN/BLK
822
21
PPL/WHT
821
22
RED/BLK
1230
23
DK BLU/WHT
1231
24
DK BLU
417
TP Sensor Signal
25
TAN
472
IAT Sensor Signal
26
PPL
2121
Ignition Control 1
27
RED
2127
Ignition Control 7
28
LT BLU/WHT
2126
Ignition Control 6
29
DK GRN/WHT
2124
Ignition Control 4
30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
DK GRN
1614
34
DK GRN/WHT
428
35
Not Used
36
BRN
436
37-38
Not Used
39
RED
631
40
BLK/WHT
451
PCM Ground
41
WHT
257
EGR Solenoid Ground
42
TAN/BLK
422
43
DK GRN/WHT
459
44
Not Used
45
WHT
1310
46
BRN/WHT
419
47
YEL/BLK
1223
48
LT GRN
1222
49
YEL/BLK
1827
50
DK GRN/WHT
817
51
YEL/BLK
1227
52-53
Not Used
54
PPL
1589
55
DK GRN
603
56
Not Used
57
BLK
552
IAT Sensor Ground
58-59
Not Used
60
BRN
2129
61
BRN/WHT
2130
62
GRA
773
PRND C
63
PNK
1224
64
DK GRN
890
65
Not Used
66
PPL/WHT
2128
Ignition Control 8
67
RED/WHT
2122
Ignition Control 2
68
DK GRN
2125
Ignition Control 5
69
LT BLU
2123
Ignition Control 3
70-75
Not Used
76
LT GRN/WHT
1749
IAC Coil B High
77
LT GRN/BLK
444
IAC Coil B Low
78
LT BLU/BLK
1748
IAC Coil A Low
79
LT BLU/WHT
1747
IAC Coil A High
80
Not Used
• TPA 12176408 (BLU)
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
PCM Ground
2
LT GRN
1867
3
PNK/BLK
1746
Injector 3 Control
4
LT GRN/BLK
1745
Injector 2 Control
5-10
Not Used
11
LT BLU
1876
12
DK BLU/WHT
1869
13-16
Not Used
17
DK BLU
1225
18
RED
1226
19
PNK
439
PCM Ignition Supply
20
ORN
440
PCM Battery Supply
21
YEL/BLK
1868
22
Not Used
23
PPL
719
Sensor Ground
24
Not Used
25
TAN
1671
26
TAN
1667
27
Not Used
28
TAN/WHT
1669
29
TAN/WHT
1653
30
LT GRN
1478
31
Not Used
32
BLK/WHT
771
PRND A Input
33
PPL
420
TCC Brake Switch
34
WHT
776
PRND P Input
35
GRA
48
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38-39
Not Used
40
BLK/WHT
451
PCM Ground
41
BLK
407
Sensor Ground
42
Not Used
43
RED/BLK
877
Injector 7 Control
44
LT BLU/BLK
844
Injector 4 Control
45
GRA
474
46
GRA
416
47
GRA
597
48
GRA
596
49-50
Not Used
51
DK BLU
496
52
Not Used
53
BLK
470
54
BLK
452
TP Sensor Ground
55
BRN
1456
56
Not Used
57
ORN
440
PCM Battery Supply
58
DK GRN
1049
Serial Data
59
YEL
710
Serial Data
60
ORN/BLK
469
MAP Sensor Ground
61
PNK/BLK
632
CMP Sensor Ground
62
Not Used
63
GRA
720
64
Not Used
65
PPL
1670
66
PPL
1666
67
Not Used
68
PPL/WHT
1668
69
PPL/WHT
1665
70
BRN
1174
71
Not Used
72
YEL
772
PRND B Input
73
BRN/WHT
633
74
YEL
410
75
PNK
1020
PCM Ignition Supply
76
BLK/WHT
845
Injector 5 Control
77
DK BLU/WHT
878
Injector 8 Control
78
Not Used
79
WHT
687
80
ORN/BLK
510
• TPA 12176410 (RED)
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
PCM Ground
2
BRN
418
3-5
Not Used
6
RED/BLK
1228
7
RED
1676
EGR Solenoid Supply
8
LT BLU/WHT
1229
9
DK GRN/WHT
465
10
WHT
121
11
DK BLU
604
12
Not Used
13
LT BLU/BLK
396
14
Not Used
15
BRN
25
16
GRA/BLK
1694
17
DK GRN/WHT
762
A/C Request Signal
18
Not Used
19
BLK/WHT
1695
20
LT GRN/BLK
822
21
PPL/WHT
821
22
RED/BLK
1230
23
DK BLU/WHT
1231
24
DK BLU
417
TP Sensor Signal
25
TAN
472
IAT Sensor Signal
26
PPL
2121
Ignition Control 1
27
RED
2127
Ignition Control 7
28
LT BLU/WHT
2126
Ignition Control 6
29
DK GRN/WHT
2124
Ignition Control 4
30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
DK GRN
1614
34
DK GRN/WHT
428
35
Not Used
36
BRN
436
37-38
Not Used
39
RED
631
40
BLK/WHT
451
PCM Ground
41
WHT
257
EGR Solenoid Ground
42
TAN/BLK
422
43
DK GRN/WHT
459
44
Not Used
45
WHT
1310
46
BRN/WHT
419
47
YEL/BLK
1223
48
LT GRN
1222
49
YEL/BLK
1827
50
DK GRN/WHT
817
51
YEL/BLK
1227
52-53
Not Used
54
PPL
1589
55
DK GRN
603
56
Not Used
57
BLK
552
IAT Sensor Ground
58-59
Not Used
60
BRN
2129
61
BRN/WHT
2130
62
GRA
773
PRND C
63
PNK
1224
64
DK GRN
890
65
Not Used
66
PPL/WHT
2128
Ignition Control 8
67
RED/WHT
2122
Ignition Control 2
68
DK GRN
2125
Ignition Control 5
69
LT BLU
2123
Ignition Control 3
70-75
Not Used
76
LT GRN/WHT
1749
IAC Coil B High
77
LT GRN/BLK
444
IAC Coil B Low
78
LT BLU/BLK
1748
IAC Coil A Low
79
LT BLU/WHT
1747
IAC Coil A High
80
Not Used
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
PCM Ground
2
LT GRN
1867
3
PNK/BLK
1746
Injector 3 Control
4
LT GRN/BLK
1745
Injector 2 Control
5-10
Not Used
11
LT BLU
1876
12
DK BLU/WHT
1869
13-16
Not Used
17
DK BLU
1225
18
RED
1226
19
PNK
439
PCM Ignition Supply
20
ORN
440
PCM Battery Supply
21
YEL/BLK
1868
22
Not Used
23
PPL
719
Sensor Ground
24
Not Used
25
TAN
1671
26
TAN
1667
27
Not Used
28
TAN/WHT
1669
29
TAN/WHT
1653
30
LT GRN
1478
31
Not Used
32
BLK/WHT
771
PRND A Input
33
PPL
420
TCC Brake Switch
34
WHT
776
PRND P Input
35
GRA
48
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38-39
Not Used
40
BLK/WHT
451
PCM Ground
41
BLK
407
Sensor Ground
42
Not Used
43
RED/BLK
877
Injector 7 Control
44
LT BLU/BLK
844
Injector 4 Control
45
GRA
474
46
GRA
416
47
GRA
597
48
GRA
596
49-50
Not Used
51
DK BLU
496
52
Not Used
53
BLK
470
54
BLK
452
TP Sensor Ground
55
BRN
1456
56
Not Used
57
ORN
440
PCM Battery Supply
58
DK GRN
1049
Serial Data
59
YEL
710
Serial Data
60
ORN/BLK
469
MAP Sensor Ground
61
PNK/BLK
632
CMP Sensor Ground
62
Not Used
63
GRA
720
64
Not Used
65
PPL
1670
66
PPL
1666
67
Not Used
68
PPL/WHT
1668
69
PPL/WHT
1665
70
BRN
1174
71
Not Used
72
YEL
772
PRND B Input
73
BRN/WHT
633
74
YEL
410
75
PNK
1020
PCM Ignition Supply
76
BLK/WHT
845
Injector 5 Control
77
DK BLU/WHT
878
Injector 8 Control
78
Not Used
79
WHT
687
80
ORN/BLK
510
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
PCM Ground
2
BRN
418
3-5
Not Used
6
RED/BLK
1228
7
RED
1676
EGR Solenoid Supply
8
LT BLU/WHT
1229
9
DK GRN/WHT
465
10
WHT
121
11
DK BLU
604
12
Not Used
13
LT BLU/BLK
396
14
Not Used
15
BRN
25
16
GRA/BLK
1694
17
DK GRN/WHT
762
A/C Request Signal
18
Not Used
19
BLK/WHT
1695
20
LT GRN/BLK
822
21
PPL/WHT
821
22
RED/BLK
1230
23
DK BLU/WHT
1231
24
DK BLU
417
TP Sensor Signal
25
TAN
472
IAT Sensor Signal
26
PPL
2121
Ignition Control 1
27
RED
2127
Ignition Control 7
28
LT BLU/WHT
2126
Ignition Control 6
29
DK GRN/WHT
2124
Ignition Control 4
30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
DK GRN
1614
34
DK GRN/WHT
428
35
Not Used
36
BRN
436
37-38
Not Used
39
RED
631
40
BLK/WHT
451
PCM Ground
41
WHT
257
EGR Solenoid Ground
42
TAN/BLK
422
43
DK GRN/WHT
459
44
Not Used
45
WHT
1310
46
BRN/WHT
419
47
YEL/BLK
1223
48
LT GRN
1222
49
YEL/BLK
1827
50
DK GRN/WHT
817
51
YEL/BLK
1227
52-53
Not Used
54
PPL
1589
55
DK GRN
603
56
Not Used
57
BLK
552
IAT Sensor Ground
58-59
Not Used
60
BRN
2129
61
BRN/WHT
2130
62
GRA
773
PRND C
63
PNK
1224
64
DK GRN
890
65
Not Used
66
PPL/WHT
2128
Ignition Control 8
67
RED/WHT
2122
Ignition Control 2
68
DK GRN
2125
Ignition Control 5
69
LT BLU
2123
Ignition Control 3
70-75
Not Used
76
LT GRN/WHT
1749
IAC Coil B High
77
LT GRN/BLK
444
IAC Coil B Low
78
LT BLU/BLK
1748
IAC Coil A Low
79
LT BLU/WHT
1747
IAC Coil A High
80
Not Used
• 12191110
• 80-Way F Micro-Pack 100 Series (BLU)
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
351
Ground
2
LT GRN
1867
12 Volt Reference
3
Not Used
4
LT BLU/BLK
844
Fuel Injector 4 Control
5-7
Not Used
8
GRY
2701
5 Volt Reference
9
DK BLU
496
KS Signal
10-11
Not Used
12
YEL
573
CKP Sensor Signal
13-16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B (Auto Trans only)
18
RED
1226
Transmission Fluid Pressure Switch Signal C (Auto Trans only)
19
PNK
439
Ignition 1 Voltage
20
ORN
440
Battery Positive Voltage
21
PPL
574
Low Reference
22
Not Used
23
BLK
2759
Low Reference
24-25
Not Used
26
TAN
1667
H02S Low Signal
27
Not Used
28
TAN/WHT
1669
H02S Low Signal
29
TAN/WHT
1653
H02S
30-31
Not Used
32
BLK/WHT
771
Transmission Range Sitch Signal A (Auto Trans Only)
33
PPL
420
TCC Brake Switch Input
34
WHT
776
Transmission Range Sitch Signal P (Auto Trans Only)
35
BRN/WHT
379
CPP Switch Signal
36
BLK
1744
Fuel Injector 1 Control
37
PNK/BLK
1746
Fuel Injector 3 Control
38-39
Not Used
40
BLK/WHT
351
Ground
41
BLK
2753
Exhaust Gas Recirculation Sensor - Return
42
Not Used
43
BLK/WHT
845
Fuel Injector 5 Control
44-45
Not Used
46
GRY
2709
5 Volt Reference
47
GRY
2702
5 Volt Reference
48
GRY
2704
5 Volt Reference
49
GRY
1716
Knock Sensor Return
50-52
Not Used
53
BLK
2762
Low Reference (Auto Trans Only)
54
ORN
469
Low Reference
55
BRN
1456
EGR Valve Position Sensor
56
Not Used
57
ORN
440
58
DK GRN
1049
PCM Class 2 Serial Data
59
YEL
710
Class 2 Serial Data
60
BLK
2752
Low Reference
61
PNK/BLK
632
Low Reference
62-65
Not Used
66
PPL
1666
H02S High Signal
67
Not Used
68
PPL/WHT
1668
H02S High Signal
69
PPL/WHT
1665
H02S High Signal
70-71
Not Used
72
YEL
772
Transmission Range Switch Signal B (Auto Trans only)
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
OFF/RUN/CRANK Voltage
76
LT GRN/BLK
1745
Fuel Injector 2 Control
77
YEL/BLK
846
Fuel Injector 6 Control
78
Not Used
79
WHT
687
3-2 Shift Solenoid Valve Control (Auto Trans Only)
80
BLK
2761
Low Reference
• 12191110
• 80-Way F Micro-Pack 100 Series (RED)
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
351
Ground
2
BRN
418
TCC PWM Solenoid Vavle Control (Auto Trans Only)
3-5
Not Used
6
RED/BLK
1228
PC Solenoid Valve High Control (Solenoid A)
7
RED
1676
EGR Valve Supply Voltage
8
LT BLU/WHT
1229
PC Solenoid Valve Low Control (Solenoid A)
9
DK GRN/WHT
465
10
WHT
121
Engine Speed Signal
11-12
Not Used
13
LT BLU
396
Cruise Control Engaged Signal
14
Not Used
15
RED
225
Generator Turn On Signal
16
GRY/BLK
1694
4WD Low Signal
17
DK GRN/WHT
762
A/C Request Signal
18
Not Used
19
BLK/WHT
1695
Axle Switch Signal
20
LT GRN/BLK
822
VSS Low Signal
21
PPL/WHT
821
VSS High Signal
22-23
Not Used
24
DK BLU
417
TP Sensor Signal
25
TAN
472
IAT Sensor Signal
26
WHT
423
IC Timing Control
27-30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
Not Used
34
DK GRN/WHT
428
35
Not Used
36
BRN
436
37-38
Not Used
39
RED
631
12 Volt Reference
40
BLK/WHT
351
Ground
41
WHT
257
EGR Solenoid Control
42
TAN/BLK
422
TCC Solenoid Valve Control (Auto Trans Only)
43
DK GRN/WHT
459
44
Not Used
45
WHT
1310
EVAP Canister Vent Solenoid Control
46
BRN/WHT
419
MIL Control
47
YEL/BLK
1223
2-3 Shift Solenoid Valve Control (Auto Trans Only)
48
LT GRN
1222
1-2 Shift Solenoid Valve Control (Auto Trans Only)
49
YEL/BLK
1827
Vehicle Speed Signal
50
DK GRN/WHT
817
51
YEL/BLK
1227
TFT Sensor Signal (Auto Trans Only)
52
GRY
23
Generator Field Duty Cycle Signal
53
Not Used
54
PPL
1589
55
DK GRN
603
A/C Low Pressure Switch Signal
56
Not Used
57
BLK
2760
Low Reference
58-61
Not Used
62
GRY
773
Transmission Range Switch Signal C (Auto Trans Only)
63
PNK
1224
Transmission Fluid Pressure Switch Signal A (Auto Trans Only)
64
DK GRN
890
Fuel Tank Pressure Signal
65-75
Not Used
76
LT GRN/WHT
1749
IAC Coil B High Control
77
LT GRN/BLK
444
IAC Coil B Low Control
78
LT BLU/BLK
1748
IAC Coil A Low Control
79
LT BLU/WHT
1747
IAC Coil A High Control
80
Not Used
• 12191110
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
351
Ground
2
LT GRN
1867
12 Volt Reference
3
Not Used
4
LT BLU/BLK
844
5-7
Not Used
8
GRY
2701
5 Volt Reference
9
DK BLU
496
KS Signal
10-11
Not Used
12
YEL
573
CKP Sensor Signal
13-16
Not Used
17
DK BLU
1225
18
RED
1226
19
PNK
439
Ignition 1 Voltage
20
ORN
440
21
PPL
574
Low Reference
22
Not Used
23
BLK
2759
Low Reference
24-25
Not Used
26
TAN
1667
H02S Low Signal
27
Not Used
28
TAN/WHT
1669
H02S Low Signal
29
TAN/WHT
1653
H02S
30-31
Not Used
32
BLK/WHT
771
33
PPL
420
34
WHT
776
35
BRN/WHT
379
CPP Switch Signal
36
BLK
1744
37
PNK/BLK
1746
38-39
Not Used
40
BLK/WHT
351
Ground
41
BLK
2753
42
Not Used
43
BLK/WHT
845
44-45
Not Used
46
GRY
2709
5 Volt Reference
47
GRY
2702
5 Volt Reference
48
GRY
2704
5 Volt Reference
49
GRY
1716
Knock Sensor Return
50-52
Not Used
53
BLK
2762
54
ORN
469
Low Reference
55
BRN
1456
56
Not Used
57
ORN
440
58
DK GRN
1049
59
YEL
710
Class 2 Serial Data
60
BLK
2752
Low Reference
61
PNK/BLK
632
Low Reference
62-65
Not Used
66
PPL
1666
H02S High Signal
67
Not Used
68
PPL/WHT
1668
H02S High Signal
69
PPL/WHT
1665
H02S High Signal
70-71
Not Used
72
YEL
772
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
76
LT GRN/BLK
1745
77
YEL/BLK
846
78
Not Used
79
WHT
687
80
BLK
2761
Low Reference
• 12191110
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
351
Ground
2
BRN
418
3-5
Not Used
6
RED/BLK
1228
7
RED
1676
8
LT BLU/WHT
1229
9
DK GRN/WHT
465
10
WHT
121
Engine Speed Signal
11-12
Not Used
13
LT BLU
396
14
Not Used
15
RED
225
16
GRY/BLK
1694
4WD Low Signal
17
DK GRN/WHT
762
A/C Request Signal
18
Not Used
19
BLK/WHT
1695
Axle Switch Signal
20
LT GRN/BLK
822
VSS Low Signal
21
PPL/WHT
821
VSS High Signal
22-23
Not Used
24
DK BLU
417
TP Sensor Signal
25
TAN
472
IAT Sensor Signal
26
WHT
423
IC Timing Control
27-30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
Not Used
34
DK GRN/WHT
428
35
Not Used
36
BRN
436
37-38
Not Used
39
RED
631
12 Volt Reference
40
BLK/WHT
351
Ground
41
WHT
257
42
TAN/BLK
422
43
DK GRN/WHT
459
44
Not Used
45
WHT
1310
46
BRN/WHT
419
MIL Control
47
YEL/BLK
1223
48
LT GRN
1222
49
YEL/BLK
1827
50
DK GRN/WHT
817
51
YEL/BLK
1227
52
GRY
23
53
Not Used
54
PPL
1589
55
DK GRN
603
56
Not Used
57
BLK
2760
Low Reference
58-61
Not Used
62
GRY
773
63
PNK
1224
64
DK GRN
890
65-75
Not Used
76
LT GRN/WHT
1749
77
LT GRN/BLK
444
78
LT BLU/BLK
1748
79
LT BLU/WHT
1747
80
Not Used
