Accessories - just brackets?
With all the different cars (and trucks) that have had the LS1 engines installed (thats LS1-6, LQ4/9 LR4 etc) how compatible are the accessories?
For instance are the accessories fitted to an F-body the same as the like an LY6 SSR?
Now I know the brackets are different, but are the main accessories the same / have the mounting / bolt patterns?
Hope you guys can set me straight!
thanks Rob
but the 'hollander interchange' (what salvage yards in US use)
shows for example a 98 ls1 alternator is different than 99-02 alternator, but an 04 SSR is same as most trucks (03-05, including the saab 9-7x)
this could really get confusing lol
good luck sir!
seeing as I haven't had any luck getting hold of a complete set of accessories and brackets I have been looking at sourcing all the parts individually... but brackets seem to be quite rare - unless I am looking in the wrong places?
I have seen some auctions on ebay for a set of F-body bracket kits but they don't include the AC brackets...
Whats would a good price for a set OEM replacement brackets?
If you look in the FAQ / Sticky, you will find many of the F-Body part numbers for all of the front accessories..
There are different A/C Bracket for each of the three spacing setups and also there could be different brackets for difference years of the F-Body and Truck.. I know I picked up a used A/C compressor and found out that I could not use it cause the bracket and compressor had different casting/mounts for my 99 F-Body compressor setup !?
When I needed an F body alternator bracket I had to get one from GM direct. Price isn't too bad. If nothing else they give you a price reference should you find some used stuff.
As for the PS pump and alternator commonality, there is always differences between the years but for the most part they should interchange. Water pumps are completely different animals between the truck, F body and vette. Someone already mentioned they all run the belt at a different distance from the engine.
GM Performance parts offers a kit for the LS1 and LS6 that has everything including the A/C for a Y car setup and a different one for LS2, LS3 and LS7
19155066 NEW
Serpentine Accessory Drive System, with Air Conditioning
• Fits LS1 and LS6 engines
• Deluxe kit includes all the components and hardware necessary
to install on an engine with air conditioning, including alternator,
power steering pump and idler bracket, (belt included)
The system includes:
12572188 Belt (water pump, alternator, and power steering)
12569528 Belt (A/C compressor)
12568181 Tensioner Assembly
12560345 A/C Belt Tensioner Assembly
12557334 A/C Compressor Idler Pulley
1137031 A/C Compressor
12556444 A/C Compressor Bracket
15261472 Power Steering Pump (reman)
12555222 Power Steering Bracket
12578068 Alternator and Power Steering Pump Bracket
12555693 Power Steering Pump Brace
12559890 Power Steering Pump Pulley
10353440 Alternator
26046502 Power Steering Reservoir
19155067 NEW
• Fits LS2 and LS7 engines
• Deluxe kit included all the components and hardware necessary
12579229 Belt (water pump, alternator, and power steering)
12585476 Belt (A/C compressor, LS7)
12569301 Tensioner Assembly
12595289 A/C Belt Tensioner Assembly
12568996 Idler Pulley
88958093 A/C Compressor
12569286 A/C Compressor Bracket
12578067 Alternator and Power Steering Pump Bracket
12568997 Power Steering Pump Pulley
15841234 Alternator
12579228 Belt (A/C compressor, LS2)
This attachment is from S&P and shows all of the different options from GM.
Fast: My project is actually a close copy of another member here (lstvr) he made up his own headers and own brackets for the ALT and PS pump, but in any case the main problem is exhaust routing out of the header. The exhaust has to follow the block down to the pan then go back, I have pics but they are not mine.
The f-body setup is expected to fit with exception of AC which will most likely foul the exhaust path on the passenger side(us pass/UK driver side). See trouble is that I am the only person who is preparing to do this conversion, into one of these:
(pic is random one plucked from google) and wants to keep the AC... and as I don't want to pay through the teeth to get custom brackets made up over here (imagine twice the cost of custom brackets in the US), I want to straight up use the GM parts.69lt1bird: I appreciate the list, I have come across a couple of those part numbers before, the list is nice to have. My problem is that I have been working to advice (from people who have gone before me) that the 'vette configuration won't give enough clearance for the headers to exit and pass down by the block, the chassis and engine bay is very space constrained (made for a narrower taller ohc engine and even the headers on the OEM engine go forward then down and back under the engine).
The f-body one is a better fit but will still be close. Is there a package for f-body package? That pdf is good, is that f-body pic of a 98? just the water pump pulley looks different to what I have seen on the ones for sale.
loweredd: I am very interested, do you know if these accessories would allow connection to a 99-02 LS1 ECM/harness, I know there are differences but not sure what they are outside of the ECM. Please PM me when you are ready and I'll give you my email address.
I guess my other question would be would the harness connectors be different? And has anyone mounted the AC compressor backward (so that the pulley rotates backward) I expect it wouldn't work, but I don't know anything to say yes or no...
Thanks again guys!
Last edited by UKRob; Aug 14, 2008 at 03:42 PM. Reason: added a comment for lowered...
I would think that you should be able to repin different plugs...... I don't know for sure though....sorry.
fast: As I have them I will, still waiting on the main engine parts (from thunder) to be shipped over from the states to england, and I may be delaying the shipment so the accessories can come over at the same time...
Will it bolt up? Looks like it will in the pic below, but IDK for sure. I have an Extra F-Body Alternator Bracket if anyone needs one.
