Ls2 Swap into Triumph Wagon. One of a kind!!
The round this is actually a speaker that was just sitting there.
As far as the q45 diff, i chose it because of the gear ratio and i know a few people who have done very well with them. BEsides, i got the entire rear end including brakes and everything for cheap. I'm sending the axles to moser to be shortened and re-splined.
You can use the Q45 diff in the 240 subframe by using the drivers side Q45 axle on the passenger side of the 240 and a drivers side 300zx twin turbo axle on the drivers side. You also need to use either the Q45 hubs or the twin turbo hubs. Everything else bolts up. I am about to install the whole setup in my 240. Good luck with yours.
Tim
Dave - Mind if i link to a couple of the pics you sent me? I also sent you a link yesterday for the 10 on ebay.
As far as my build is going, i'm investigating going with l92 heads. I'm going to pull the stock ls2 heads off today and see what the pistons look like....
#34
I'm looking into some body mods for sure. So far, the the possibility of carbon fiber front fenders/hood/trunk door and looking pretty good. the rear fenders might have to be fiberglass. We'll see :-)
#35
Who's doin the carbonfiber work for you? I wish I could find carbonfiber fenders for the Nova, strong and light.
#38
In regards to the carbon fiber, i've got a local friend who used to do it for a living until recently. We'll start with the hood, and the plan is for me to learn enough to do the rest on my own. It could turn out awesome, it could suck ***. Hopefully, it'll be the former.
