84 C10 Fuel System Question
My question is: how should I attach the hose to the filter end given it still has the factory quick disc ring on the two lines and I cant slip the rubber hose over the ring ? Do I cut the quick disc part off or try to work the hose on over the ring and then clamp it? I am using the FI clamps & all but I am worried about the hi pressure line staying put and not leaking. Please Help!
http://www.midwayautosupply.com/
3/8" female connector DOR-800-121
5/16" female connector DOR-800-120
or you can check your local auto parts store.
Make sure you use the good FI hose clamps not the rinky dink 10 for a dollar ones.
I am using these adapters and have no problems.
I think you can also get Dorman parts at Napa, if you have one of those locally.
