Totally wired from wiring!! Almost done...help!
Here's where I'm stuck...I'm not sure what to do with the following Pins/wires
C100 Pin R Engine On signal.......is it needed?
C152 Pin E Vehicle Speed Signal.....I used the GN/Wh wire from PCM C2 pin 50. Do I remove the extra speed signal?
C152 Pin C 5volt reference Gray...can it go?
C152 Pin J Low reference Blk Ckt 470...can it go too?
C2 Position A10 CHMSL supply voltage/stoplamp supply voltage....needed?
In the past 12hrs I've grouped the pinks according to circuits, pulled and labeled tach, speedo, start/solenoid wiring. My harness has one plug I found nowhere on LS1tech, so I bought the alldatadiy schematics, but still can't tell if I need any of this. Here's the plug, it's near the pcm. My generator is a two plug deal. I've had the entire harness on. Every plug except this one were taken.
