couple of problems/questions...
Old Oct 21, 2008 | 09:41 AM
  #41
lq4cutlass's Avatar
shoot...i think the guy might have thrown that away...can i buy the cable online?
Old Oct 21, 2008 | 09:42 AM
  #42
lq4cutlass's Avatar
Originally Posted by Ravenous T\A
look like this one on the bottom left of the picture
nope my box is red and smaller...and its mounted on the intake..
Old Oct 21, 2008 | 09:46 AM
  #43
lq4cutlass's Avatar
and my intake isnt that high...
  #44
SMAX's Avatar
You have the edelbrock box. Just use pill #2 or 3.
Old Oct 21, 2008 | 09:52 AM
  #45
lq4cutlass's Avatar
any diffrence between the two?
would a Air/Fuel Ratio (EGT) Monitoring System be any help? if so whats a good "round guage style" you guys can reccomend?
thanks a million AGAIN
Old Oct 21, 2008 | 09:56 AM
  #46
SMAX's Avatar
The edelbrock ignition box is not programable and the msd is.
You would want a wideband o2 sensor.
Is this a daily driver or a weekend warrior type vehicle for you?
Old Oct 21, 2008 | 09:57 AM
  #47
lq4cutlass's Avatar
sunday driver
Old Oct 21, 2008 | 10:01 AM
  #48
SMAX's Avatar
I would ditch the 750hp and go to a different carb. From the way you describe your intake it sounds like you have an edelbrock performer rpm intake(dual plane) and the edelbrock ignition box. The holley 750hp is a more race oriented carb and is going to give you alot of headaches with the type of driving you intend to do.
I would look at a vacuum secondary carb maybe in the 650cfm range. Maybe even look at the edelbrock carbs like Ravenous mentioned.
Old Oct 21, 2008 | 10:13 AM
  #49
lq4cutlass's Avatar
honestly i don't wanna do that...last thing i wanna do is buy a new carb...i rather try to fix this one..its BRAND NEW..probly has like 8 hours MAX use!
Old Oct 21, 2008 | 10:14 AM
  #50
Ravenous T\A's Avatar
u can use this to see what size carb best suits your needs. What size cam are u running?
http://www.4secondsflat.com/Carb_CFM_Calculator.html
Old Oct 21, 2008 | 10:23 AM
  #51
SMAX's Avatar
You can use it. You should probably learn to tune it on your own though because you are probably going to want to adjust it quite often.
Old Oct 21, 2008 | 10:25 AM
  #52
lq4cutlass's Avatar
honestly i don't know, all i know is that its a Comp Cam and the guy told me its a mild cam..
Old Oct 21, 2008 | 10:26 AM
  #53
lq4cutlass's Avatar
well thats what i was thinking, ill take it to this guy, have him tune it and at the same time teach me
Old Oct 21, 2008 | 10:30 AM
  #54
Best way to do it...im too stupid to learn how to do it hahah rather just pay someone
Old Oct 21, 2008 | 10:32 AM
  #55
lq4cutlass's Avatar
i also got a 150 shot of nitrous, but haven't installed it ti'll i get the motor running right...
should i install the nitrous THEN have it tuned or have it tuned THEN install the nitrous?
Old Oct 21, 2008 | 10:47 AM
  #56
SMAX's Avatar
Get it running correctly before you put it on the bottle.
You don't want a lean condition with nitrous.
Old Oct 21, 2008 | 10:50 AM
  #57
lq4cutlass's Avatar
and how do i know if a coil needs changing?
lets see if next weekend when i get paid i'll take to a PRO lol
thanks alot guys!! alot of helpful info!
Old Oct 21, 2008 | 10:52 AM
  #58
MalibuRacing's Avatar
I don't mean to come off sounding like a jerk, but I think you're getting some bad advice. Holley carbs aren't VooDoo or rocket science. They're pretty simple IMHO. They are more performance oriented, so yes, they do normally require some tuning. But, my experience with them is they run great and trouble free once properly tuned. I have used Edelbrock (Carter AFB) type carbs and like them also, but don't ditch your carb just yet. The carb you have is a really nice carb.
As was stated previously, you FIRST and FOREMOST need to verify ACTUAL fuel pressure before you do any carb tuning or anything else for that matter. ESPECIALLY if you're only seeing a true 2.5 psi fuel pressure, you need to address that issue first. All this tuning advice you're getting (including changing carbs) doesn't do you one bit of good. You need a MINIMUM of 4 psi at WOT and a max around 7 psi of fuel pressure at idle. You can spend all the time and money you want on carbs, jets, extensions, power valves, but they won't do diddly squat if you don't have the the proper fuel pressure.
Did you ever tell what type of fuel pump and regulator you're using? Do you use a regulator? Is it a return type or dead head? I'd be curious to know your exact setup.
Old Oct 21, 2008 | 11:00 AM
  #59
lq4cutlass's Avatar
i listed the fuel pump..i will list everything in detail when i get home from work today..
Old Oct 21, 2008 | 11:18 AM
  #60
onequikss's Avatar
How do you have the fuel pump wired? If your fuel pressure is dropping 4psi when it gets hot, it has nothing to do with how the carb is tuned. Make shure that you have a good ground and heavy enough gauge wire to power the pump. If you are just cruising around the pump probably has enough pressure to keep the car running and fuel in the bowls, but when you hit it and it uses all of the fuel in the bowls it can no longer keep up.
