FM Turbo ls1 in a 3rd gen
Old Oct 27, 2008 | 06:29 PM
4SFEDSS's Avatar
So are you planning to get started on these soon? I'd like to have some by spring, but if not i'll have to make my own and i dont really want to deal with it.
Old Oct 28, 2008 | 11:02 AM
89L98T56's Avatar
Let's ******* do this thing man...I'll order these ******* today!!! lol
Old Oct 28, 2008 | 11:10 AM
MeanYellowZ's Avatar
I am finishing up a vette for a guy....should be within the next 3-4 weeks, then I can start on the thirdgen stuff. Is anyone interested in logtype manifolds or just the tube headers? Obviously if its made from stainless it will be a little pricey. I will start working on a set and then post some details.
Old Oct 28, 2008 | 02:42 PM
V8Rumble's Avatar
I wouldn't be opposed to a log-type if it was 1) simple to make (to keep the costs down), & 2) sturdy enough to provide some support to a moderately-sized turbo. I've seen some builds that are using log-type manifolds & making some really good power...
Just my 2c...
Old Oct 28, 2008 | 03:35 PM
A thick log type setup would be cost effective and more importantly last a lot longer in all conditions than the tube setup.
Old Oct 28, 2008 | 04:25 PM
89L98T56's Avatar
What kind of material would it be made from? Mild steel? It would be awesome if a crossover pipe and turbo flange was attached man, atleast if I get a set maybe for an extra charge you could do this for me???
Old Oct 29, 2008 | 03:24 AM
89LS1RS's Avatar
if i didnt like my headers so much, and the rest of the dual 3" exhaust to match, i would have done this already. im thinking of a rear mount setup, but theres just not enough room for the pipes ive got and new ones to the front. i have manifolds that i cut the flanges off, and rolled the opening to a round 3"(it was kind of ovaled). i have some 3" stainless i was going to weld to them, so i can position the pipe wherever it needs to be. then put a flange for the turbo, and so on. i have the bmr kmember and a manual rack, so it helps a lot with room. and i have the s+p accessory setup where the ac is up on passenger, alt is up on driver. plenty of room for pipes to come forward, plenty of room for twins if i wanted.
Old Oct 29, 2008 | 07:18 AM
NemeSS's Avatar
im working on a t4 turbo pass. side hi mount
with remote wg, and x-over for use with factory exhaust manifold on driver side. looking to use a truck manifold on the driver side since they are plentiful, cheap, and can be picked up at just about any salvage yard nationally. it will be a manifold/log type piece.
Old Oct 29, 2008 | 10:46 AM
89L98T56's Avatar
This is going in a third gen?
Old Oct 29, 2008 | 06:40 PM
4SFEDSS's Avatar
What do you plan to use on the passenger side?
Old Oct 29, 2008 | 11:11 PM
NemeSS's Avatar
CORRECT, 3rd gen lsx swap
fabricated log/manifold type hi mount t4 manifold being fed from drivers side using a oem exhaust manifold and 2.5 tubing for x-over
vband flange sealing, 3.0-3.5 dp whatever i squeeze without melting anything
concentrating on making plug access a priority
Old Oct 30, 2008 | 08:07 AM
  #32
89L98T56's Avatar
Got any pics?
Are you fabbing this up yourself??
Old Oct 30, 2008 | 06:52 PM
  #33
4SFEDSS's Avatar
Lightbulb
Is it possible to use any factory manifold on the passenger side?
Old Nov 1, 2008 | 09:21 PM
  #34
NemeSS's Avatar
Got any pics?
i will take pics once i feel that everything looks right.
yes, im fabbing myself
Old Nov 1, 2008 | 09:24 PM
  #35
NemeSS's Avatar
passenger side will have turbo manifold being fed by driver side oem exhaust manifold and crossover.
im looking into c6 ls2 manifold, since i have set
but really concebtrating on using truck manifold, forthe system since they are inexpensive and readily available. the lower in price the better.
Old Nov 2, 2008 | 03:06 PM
  #36
89L98T56's Avatar
Very true... What are the specs on the engine? etc..
Old Nov 7, 2008 | 07:26 PM
  #37
4SFEDSS's Avatar
We are in the process of doing a 91Z right now with truck manifolds facing forward with some stock k-member modifications......
Any updates on the project?
