06 4l60e pnp switch wiring
Old Oct 25, 2008 | 09:13 PM
flbullet's Avatar
Default 06 4l60e pnp switch wiring
Does anyone have the pin outs for the pnp switch on a 2006 4l60e trans-single plug 12 pin? thanks!!
Old Oct 27, 2008 | 10:07 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
What did the trans come from? Year, make and model or wiring would really help....
Old Oct 27, 2008 | 09:02 PM
flbullet's Avatar
trans came out of an '06 silverado pu 2wd - engine is and '03 6.0l from a denali
thanks
Old Oct 27, 2008 | 09:08 PM
poconojoe's Avatar
If it looks like this connector, here is the pin out
http://connectors.delphi.com/DCSGDMC...rtNum=15416722
Pin
Wire Color
Circuit No.
Function
1
DK GRN
1433
Clutch Start Switch Signal
2-3
Not Used
4
YEL
772
Transmission Range Switch Signal B
5
BLK/WHT
771
Transmission Range Switch Signal A
6
GRY
773
Transmission Range Switch Signal C
7
BLK/WHT
451
Ground
8
WHT
776
Transmission Range Switch Signal P
9
LT GRN
275
Park Neutral Position Switch Signal
10
GRY
1524
Back-Up Lamp Supply Voltage
11
PNK
839
Ignition 1 Voltage
12
PNK
639
Ignition 1 Voltage
Old Oct 28, 2008 | 09:09 PM
flbullet's Avatar
Thumbs up
that is the connector and the info i am looking for - thanks!!!!
Old Feb 12, 2009 | 01:09 PM
INC0G's Avatar
what is the name of the part that this plugs into? please help!
Old Feb 13, 2009 | 07:48 AM
Old Geezer's Avatar
Default It plugs
into the neutral start switch, that's mounted at the shifter lever.
Old Feb 13, 2009 | 10:24 AM
LS1DIME's Avatar
That would technically be the Transmission Range Sensor!
Old Feb 13, 2009 | 01:56 PM
Old Geezer's Avatar
Lightbulb My bad1
I'm not a very "technical" person..
Old Feb 16, 2009 | 09:10 PM
LS1DIME's Avatar
Lol, i just wanted ya to know what to look for!
Old Feb 17, 2009 | 07:13 AM
Old Geezer's Avatar
Talking My career..
started out as a heart surgeon. Then I moved into nuclear biochemistry. But as I got older, I found that working on cars was so much more rewarding. That's why I missed the correct terminology on the selector!!
Old Jun 13, 2011 | 11:45 AM
BryanD's Avatar
can anyone tell what the "range switch signal" is? i.e. 12V+, 12V-, 5V, etc?
