thinking about a 5.3 in jeep yj!!
I know there are both adapters out there to adapt the GM engine to the jeep transmission and also adapters to adapt gm transmissions to the jeep transfercase. I am not sure what would be the best solution. I can get a th350 trans pretty cheap that would bolt right up to the engine than I would have to get the adpater for the transfer-case.
Any input and suggestions would be greatly appreciated guys. Thanks!!
You you'll need a driver side drop transfer case Like a Gm NP241 with a VSS and a 4l60e. Then you have the option of a slip yoke eliminator to help with the rear drive shaft length. Plus it will have a decent low range and little more strength than a NP231 but you can get adapters to use the Jeep NP231 just add a VSS.
The axles aren't just going to blow up, but will break. **** I would run them till they break then swap in some dana 44's later to save money up front.
I'm working on a similar project. I'm putting a 5.3/4l60e into a 1985 Toyota truck that is being built as a dedicated trail rig. V8 power, 1 ton axles, and 40 plus inch tires.
That said, I don't expect these axles to live forever either. Planning on a D60 swap eventually.
The stock AX-15 trans is definitely on the weak side, I'd upgrade if I were you. NV3550 or 3500 or whatever it is the 1/2 tons used might be a good choice, NV4500s are damn good but probably overkill for a mild rig.
If you use a 700R4 the t-case swap is easy. Pick up an S-10 NP231, pull the input shaft and planetary assembly out, and throw it in place of the ones in the Jeep case. If you're lucky the S-10 setup will even be a 6-planetary instead of the 3 that Jeep used. At most you might need to buy a clocking ring for $75 if the hole spacing is different. My case is flipped so I'm not sure how it normally lines up with the holes on the stock adapter. Now that I think about it, just use the S-10 case. Bolt the YJ front output yoke on it and you've got the same case, drivers drop, wider/stronger chain, and 27 spline input. Some S-10 NP231s use 5 bolt mounting, some use 6 so make sure you get the right one. Don't bother with the trans out of the S-10 though, it won't bolt up to the V8.
I'm in the middle of a 6.0 swap into my Scrambler but little I've done is gonna be much help on a mild YJ build. Shoot me a PM if you have any specific questions. I'm running a 2003 LQ4, built 700R4, NP231 crawlbox with241 internals, and Dana300 backing that up. 120:1 lowrange and ~450 lb-ft should be fun.
