Carb Jet Size
Old Nov 2, 2008 | 08:31 PM
bluethunder364's Avatar
Default Carb Jet Size
My LQ-4 which has not been really tuned just yet, as I just got it up and running may need to be rejetted. I'm running a 750 HP series with the stock jetting which is 75 primary and 80 secondary. Just wondering what others may be running for jets. When I dyno the car in the spring we will have a air/fuel ratio sensor in the exhaust to determine the correct ratio. I was just wondering if the jets I have are a good place to start. Like I said it's a 364 ci lq-4 with L92 heads and a GMPP single plain intake. Thanks
Old Nov 3, 2008 | 05:08 AM
Shawn MacAnanny's Avatar
im running a holley 750, vacuum secondaries,72 primaries, 76 secondaries (roughly as they are adjust-ajets) a 50cc acclerator pump, #35 squirter, a 5.0 Power valve (you will want something like 6.5 since my cam produces next to no vacuum), and im running the white spring right now (lightest) but im going back to the short yellow spring.
I am using a Fast Dual Wideband to monitor all of my AFRs too. With this setup I have it at 13.8 at idle, 12.6-13.0 at cruise and 12.3-12.8 at WOT. I am also running a Holley 97GPH fuel pump wired with 10AWG house wire that makes 8psi at 14.2volts.
Old Nov 3, 2008 | 08:07 AM
forcd ind's Avatar
i would start with stock jetting first, do some plug readings, get it close before dyno time-mine needed a pretty agressive shot off idle, i had to switch to the green pump cam, but your head/intake is diff(i had lq9/vic jr)
you just have ti drive it, see what it does, tune from there
Old Nov 3, 2008 | 09:41 AM
Thanks for the info
Old Nov 3, 2008 | 12:53 PM
mred's Avatar
i wouldnt, i would start off with square on the jets spreading the jets is like dirt track racing tune or something also why not just buy a spreads bore carb. bigger squirters front and rear.
make sure your idle air screws are adjusted properly,more than a full turn is out of adjust.
50cc pumps???
come on now, if your using 50cc for street use, you really need to get to the basics for carb tuning.
especially on a simple motor as such.
Old Nov 3, 2008 | 01:59 PM
Pop N Wood's Avatar
50cc pumps???
And what are you running on your carb'd LS motor?
I pretty much have Shawn's set up, as are most of the other guys on here. Has been talked about in great detail. These motors seem to need more of a shot than the first gen SBC's
https://ls1tech.com/forums/conversions-swaps/972427-carb-d-ls2-accel-pump-size.html
Old Nov 3, 2008 | 06:25 PM
50cc pumps???
Yeah LS1s flow ALOT more than any SBC due to their 15 degree style heads and catherdral ports. Mate that with the Victor JR intake and you need ALOT of fuel when the throttle blades open. I still have a slight stumble in gear cruising but thats just a matter of swapping out a few cams. This is a on a vacuum secondary carb, not double pumper.
I'm runing my screws turned 1 1/2 turns out. I've been tuning this carb for quite sometime now. Tried a couple accelerator pumps, tried a 25, 29, 35 squirter with hollow screw. A few cams, a few jets (running adjust-a-jets now), a few springs, a few power valves. It's all been trial an error not just assumption. I'm also using one of the most accurate A/F monitoring systems, mated with a computer controller and monitored ignition system with a MAP sensor. It's not like changing the springs and weights and turning of the old systems nor the 'plug reading' like the old school.
