truck fuel rail
Old Sep 23, 2003 | 09:06 PM
Gen3Benz's Avatar
Default truck fuel rail
Will the LS1 and 5.3 truck fuel rails interchange?? Are the injector spacing and mounting hole locations way far off? The truck fuel rail has a return line and a vacuum fuel regulator, it would work great for a return fuel system. And its cheaper than the $165 S&P modified fuel rail. Also does the 96-97 corvette fuel rail have a return line?
Old Sep 23, 2003 | 09:38 PM
88SS LS1's Avatar
Default Re: truck fuel rail
pretty much if you want a return line you could go to S&P and buy a corvette fuel rail from a 97 or have them exchange out one of their rails that have the return line or you go and get a aeromotive regulator for about $140.00 and do the same thing. And use any normal ls1 fuel rail. The truck rails and the LS1 rails do not interchange.
Old Sep 24, 2003 | 06:55 AM
67ls1CamaroProject's Avatar
Why does everyone want a return line at the rail? Just get a 99 vette fuel regulator/filter. It comes with three ports...in/out/return. Mounts anywhere you want. Close to the tank is best for a short return line...and keep the truck rails.
Old Sep 24, 2003 | 04:40 PM
LS1swap's Avatar
Just out of curiosity what is the part number and cost of the Vette filter/regulator?. I used the Mallory four port regulator. It cost me around $70 if I remember it right. I liked it because it gave me a good spot for my fuel pressure gauge.
Old Sep 24, 2003 | 11:38 PM
John B's Avatar
Moderator
It ensures a continuous supply of cold fuel at the engine.
Old Sep 25, 2003 | 11:31 AM
I paid $31 from GMPartsdirect.com shipped. The dealer wants around $60.
