Intake Manifold
Old Nov 30, 2008 | 11:07 AM
gold00's Avatar
Default Intake Manifold
I have an 06 Vortec in my 69 Chevelle that I would like to replace the intake on and get rid of some of the clutter from unused bolt downs and such. Can I use a intake from an LS engine if not does anyone know where I can buy one for a Vortec searched but came up empty!
Old Nov 30, 2008 | 12:13 PM
65SSZO6's Avatar
Vortec is a "branding" name of motors,usually referring to the truck and SUV versions of the LS engine family.What exactly did your motor come out of? If you are interested in a LS1(flat criss/cross intake like out of a FBody or Corvette) PM me.You will most likely need to chage injectors and fuel rail too.
Old Nov 30, 2008 | 02:08 PM
V8Rumble's Avatar
Take a picture of what you have, & post it here.
Old Nov 30, 2008 | 04:57 PM
gold00's Avatar
It came out of an 06 Sierra. It is a L33 Gen 3 Alum block HO engine.
Attached Thumbnails Intake Manifold-100_1018.jpg   Intake Manifold-100_1014.jpg
Old Nov 30, 2008 | 10:13 PM
V8Rumble's Avatar
Oh yeah, that looks pretty familiar! OK, I'm guessing (pretty sure) that it has the std rectangle-port intake, which would mean that you'd need to get the L76 intake manifold to work with that style port.
If I'm mistaken & it has the "cathedral" intake ports (shaped tall & skinny, & tapering to a near-point at the top), then you could use the LS1 or LS6 type intake manifolds.
Another alternative that I remember reading about was someone taking a dremel or a die grinder to the top of the truck intake to remove a lot of the extraneous crap, then smoothed it out a bit & finished it with some paint. As I recall, it looked pretty good!
Hope this helps.
Old Nov 30, 2008 | 11:36 PM
the_merv's Avatar
Veteran: Air Force
The Rectangular Port Heads came out in '07, his is still Cathedral Port Heads.
I would use an LS6 Intake, and get Car Accessories..
Old Nov 30, 2008 | 11:39 PM
ls1_chevelle's Avatar
or just put a pipe on the water pump outlet on the top and turn it to clear to save some coin. Done it before, same with a couple other members.
