Gauge issues for LS2 swap
Help
Look at my 65 Chevelle thread for ideas on hooking up your other gauges.
But for the tach, I found an Isspro tach that had exactly the same sweep as my tach. The faceplate mounting holes were even in the same place and the vette needle pressed right on. A little fabrication and it works great and looks original.
I found an adapter for the oil, and I tapped the block plug for my temp gauge.
fuel gauge works, i need a new sending unit for temp, volt I can just run to the system somewhere...oil pressure I tapped the small removable piece that bolts to the oil pan above the oil filter for my factory sending unit
speedometer: there is a company that makes a talihousing for both VSS and mechanical speedo outputs, but its $500
