drive-by-wire to drive-by-cable?
Old Dec 3, 2008 | 03:24 PM
Stev0n's Avatar
Default drive-by-wire to drive-by-cable?
so i picked up an 05 5.3 w/ 18k miles for under $500.
One problem is I don't want drive-by-wire. How hard is it to switch to cable driven in regards to running a cable, switching the TB, and the ECU itself thinking i'm still d-b-w once done. (i've searched, but apparently i don't ever seem to type in the right 'keywords' to find what i'm looking for)
Old Dec 3, 2008 | 05:00 PM
LUMPY85's Avatar
damn i would have traded you all the stuff and paid shipping, DBW is nice IMO. all your cruise control stuff is in the TB, and there really isnt a difference that i know of. my silverado ran great nad had great response with the dbw setup
Old Dec 3, 2008 | 06:35 PM
Stev0n's Avatar
dbw is nice, but apparently i have to have some special pedal setup or something, and that just extra trouble i dont want.
Old Dec 3, 2008 | 07:57 PM
busta9876's Avatar
The cable throttle body will bolt right on. What you have to deal with is harness/PCM. Did you get these items?
You could get a drive by cable harness/pcm or...you could convert you're harness. You only have to add two connectors. 1 for Idle Air Control motor, and 1 for Throttle Position Sensor. Total of 7 wires. I have done this, and used the wires originally for the electric throttle body. Then added the 7 wires to the PCM connectors, and solider/heat shrink to correct wires from the TAC module connector.
As for the PCM, not sure on that one. I know the 2003 Express van's still had cable throttle where the 2003 Pickups had DBW, and used the SAME PCM. however, you'r 2005 PCM probably won't accept a 2003 calibration. It would be some custom programming to make it work.
Old Dec 7, 2008 | 01:54 AM
LQ9CHEVELLE's Avatar
Just bolt a cable throttle body on there. As for the harness....tell the harness supplier to build it for cable throttle, with the appropriate connectors. I use fuelinjectionconnection.com, but speartech also is a good choice. Unless you trimming and modifying your own harness.....then the homework is up to you! The computer has to be programmed to get rid of VATS and other assorted EVAP / Secondary 02 codes, and can be set up for cable throttle when programing, just use a 99-up "red-blue" connector ECM. Thats what has worked for me
Old Dec 7, 2008 | 02:08 AM
the_merv's Avatar
Veteran: Air Force
Doesn't it depend on what PCM you have..isn't there a different Reluctor for the DBW TB's.
Old Dec 7, 2008 | 09:19 AM
Project GatTagO's Avatar
I have an extra pedal that I will sell cheap. I live in Bowling Green too. PM me, and let me know what kind of vehicle your working on.
Andrew
Old Dec 7, 2008 | 12:01 PM
ryanvv355's Avatar
You need to be careful what computer you use. Delphi eliminated the IC in the computer for IAC control on trucks shortly after the DBW swap. You can use a computer from a vehicle that had cable TB, remember S-10's and express vans had cable TB's up to 04. If you are building your own harness when you eliminate the oil pressure sensor the connector of it works for the TPS. One of the A/C connectors will also work, don't remember which one.
Old Dec 7, 2008 | 06:10 PM
The computer can be flashed for whatever year / throttle setup you want, by a good tuner with the capability to switch the computers "operating system" (i.e.....make a 2001 truck computer run a 2001 vette dbw setup). As long as the ECM has the correct connectors (red/blue or blue/green, depending on what your harness is set up for) it can be wiped clean and set up as whatever system you need. The 97-98 vette computers are limited however, they are a different animal from what im told by my tuner.
Old Dec 10, 2008 | 12:45 PM
69 Ghost's Avatar
Set a PM. I may be interested in trading a cable setup for wire and I have everything. Send a reply if interested.
Old Jul 1, 2023 | 05:03 PM
zachand799's Avatar
hope somebody sees this, I have same problem 06 v6 5 speed wt chassis drive by cable swapping a lm7 5.3. when you get the dbw harness don’t you have to do something with the actual hook up for the wire control? I can’t find a youtube or anything anywhere. thanks!
