ls1 and ford tranny help
ultrabell 92463 is the one i found
use the ultra bell for a SBC and then use the crank spacer from a g van w/6.0l and a 4l80e. The fly wheel might be close as far as bolt pattern is concerned. DON'T drill out the upper right hand side bolt boss on the LS motor as it will hit a pressurized ouil passage.
