Carbureted Fuel System
Old Dec 12, 2008 | 04:07 PM
luckyhenriksen's Avatar
OK I'll look for a big cam
Old Dec 12, 2008 | 04:12 PM
Shawn MacAnanny's Avatar
Well i guess more important what is this engine going in again? Vehicle weight? Transmission? Projected tire size and gear ratio?
Old Dec 12, 2008 | 08:47 PM
rojs234's Avatar
Originally Posted by luckyhenriksen
Ok cool. I plan on running the MSD box and GMPP intake. I am trying to copy the build Car Craft did, they made around 550 HP at the motor. Thanks for your help, I will look for fuel pumps and regulators.
I'm not trying to talk you into any particular cam because I don't know your intended use or even what your going to put it in,but as far as your power goals, it should be no problem! Just for comparison sake, I've got a stock bore 6.0 with L92 heads and a 222x234 cam. When it had the FI , it dyno'd at526HP and I'm quite sure it's making every bit of that still with my carb setup. Car Craft ran a bigger cam and made the 550HP, so I'm sure you have a chance of hitting the number. I do think Shawn is right about choosing a cam with about 10-12 * more exhaust duration.
Old Dec 12, 2008 | 11:35 PM
I htink Car Craft might be running the biggest cam possible with the stock L92 springs? IDK...... The motor is going in my '68 Chevy C10 (My sig) which weighs around 4000 lbs., has 3:73 gears (for now, might step up to 4:11's), and a TH400. Right now the trans has a 2000 stall converter, but I want to step up to a 4000-4500 stall. Any tips on this?
Old Dec 13, 2008 | 05:49 AM
I wouldnt run a big cam with stock springs. Springs are cheap to replace. A couple hundred dollars. Its worth it just to run dual springs. I have personally broken a dual spring before on my 01 z06 and my ET heads were left undamaged.
I say a 4500 stall. You have plentry of room to run a free flowing dual exhaust setup. If you go to 4.10s then you could run 28"-30" tires in the rear.
Old Dec 13, 2008 | 02:45 PM
The GMPP Hot Cam kits come with springs, are those kits a good deal?
Old Dec 13, 2008 | 05:15 PM
The Hotcam is a baby cam. No dont get it.
Old Dec 13, 2008 | 06:04 PM
Ok, all the cam's I can find are for EFI applications, is there one that will work for carb systems?
Old Dec 13, 2008 | 06:57 PM
PM Patrick G or Predator-Z either of than can spec a cam for you and have them ground for your self. EFI cams will work fine on a carb you can just a few more hp by tightening up the LSa and adding a little duration.
Old Dec 13, 2008 | 08:21 PM
Ok thanks
