6.0 in a g body
Old Dec 30, 2008 | 06:17 PM
billyflantos's Avatar
Default 6.0 in a g body
i have a 2002 6.0 truck motor with factory aluminum heads what will it take to put it in a 85 regal,i'm going with a carb set up also need to know about motormounts and oil pan and headers what i need to put a turbo 350 behind it and what would be a good cam for that motor ,and any info on the 6.0 will be helpful hp compression ratio just want to know if it will be easy to make go fast.i already have turbo 350 with a turbo action 8 inch conv stalls 4500 off the foot brake 411 gear car weighs 2780 with a 23 degree head sm blk. and cuts low 1.40's short time off the foot brake.
Old Dec 30, 2008 | 08:39 PM
-gz-'s Avatar
http://www.youtube.com/watch?v=DRhtqrF4g-M
it shouldnt be too hard. this is a vid of something similar. its a 87 caprice with a carb'd 6.0 lq9 and a 700r4. this is what the guy said on another forum
the car has a LQ9 6.0 out of an escalade, and down here in "MIAMI" we call this body of caprice a "BOX" so thats why they call it "BOXCALADE"... anyways the motor is COMPLETELY stock except for the edelbrock cam part # 2216, and of course the performer rpm intake 750 holley & and only a 150 shot of nitrous(to get 4000lbs out the hole!) the tranny is a 700r4, a 2500 stall converter and a 4:56 posi rear and a dirty motor! THATS IT! check out some my races on youtube"BOXCALADE" let me noe wat u think...
http://www.maliburacing.com/forum/vi...69419&p=537764
hope that helps you get started in the right direction
Old Dec 30, 2008 | 08:40 PM
deuce4935's Avatar
Your 02' motor should be in the 9-10:1 cr, you can use your stock truck oilpan if the clearance isn't an issue to you or you can opt for a modified f-body oilpan or the new lh8(hummer h3) oilpan. As far as mounts go, pick your poison, there are several companies that make them, I personally chose the S&P mounts and modified f-body oilpan, and they also make the g-body lsx headers. To keep the trans and converter you will need to order the adapter plate from either GM or http://store.summitracing.com/partde...w=64&N=700+115
http://store.summitracing.com/partde...5&autoview=sku
This should get you started.
Old Dec 30, 2008 | 08:46 PM
Thanks -gz- like watching big cars hauling a$$,THANKS ALSO DEUCE 4935...
Old Dec 31, 2008 | 10:01 AM
ttttttt
Old Dec 31, 2008 | 12:41 PM
MalibuRacing's Avatar
Look here, this guy put a carbed 6.0 in a Malibu: http://www.maliburacing.com/forum/vi...p?f=29&t=56385
6.0 EFI swap into a Malibu: http://www.maliburacing.com/forum/vi...p?f=29&t=73834
My "Father/Son" project, 4.8L/4L60E EFI swap: http://www.maliburacing.com/forum/viewforum.php?f=34
Old Dec 31, 2008 | 01:54 PM
deuce_454's Avatar
hey.. its mister P. venturing off his HP :-) good you chimed in, i was going to suggest he visit your site before i saw you posted
