Simple Accessory pulley question
Old Jan 6, 2009 | 12:38 PM
garys 68's Avatar
Default Simple Accessory pulley question
Are the pulley bolts on accessory drive aligned so that the pulley rotation can only tighten the bolt? I noticed some tensioner pulleys are bolted from the backside, is this done to prevent loosening?
I just put together the accessory drive below and noticed that one pulley will be rotating counterclockwise. If it's going to loosen, I was thinking a support between the top of the 2 pulley bolts with a french lock type of mechanism to prevent loosening.
Any thoughts?
