A few random 5.3 swap questions...
Old Jan 7, 2009 | 10:26 PM
Epro's Avatar
Default A few random 5.3 swap questions...
Car in question is my 95 3.8 camaro...
Why do I have to change all my accessories? What can I keep?
What year specific sensors should I worry about? Depends on what year PCM I go with? What year specific parts should I get?
Why do I need to change the stock exhaust manifolds over to LS1 manifolds?
Old Jan 8, 2009 | 02:13 AM
the_merv's Avatar
Veteran: Air Force
I would use all LS1 F-Body Accessories for the 5.3l, you may have to Drill and Tap the Drivers side of the Block for one of the Alternator Bracket Bolts.
The only thing that I had found to be year-specific was the 1998 Temp Sensor for the Gauges and the PCM. It's a 3-wire Sensor. For me it works without a problem. I used an '02 PCM with a 1999 Harness. It's not really a 1999 Harness any more, but that's what it started out as.
Are the Truck Exhaust Manifolds the same as the Car?
Get Headers..
Old Jan 8, 2009 | 02:46 PM
Epro's Avatar
Get Headers..
I'm on a budget, if they'll work, I'll use them
Old Jan 8, 2009 | 03:51 PM
sman's Avatar
Truck and fbody manifolds are different manifolds are different.
Im in the process of this exact swap except my car is a 99, there no such thing as budget with this, SO many parts are needed. Be ready to drop some coin.
Old Jan 8, 2009 | 04:49 PM
aksz71's Avatar
as far as like headers if you go that route they work cause there are some ppl with our trucks that have f-body longtubes but minor work to em and they fit on the trucks i know
