Injectors not firing... please help
The weird thing is that when I check voltage between the two pins in the injector plug on the wire harness i get 12 volts. To restate I am getting a constant ground through the ecm with the ignition switch in the run position. If I unplug the ecm c2 connector and retest the ground goes away in the run position. Does anyone know what could cause this? Can stuck injectors cause this? Is there something wrong with the ecm?
Thanks,
Tom
[ECM] P0230 - Fuel Pump Relay Control Circuit (Pending) (Current) (Immature)
[ECM] P0443 - EVAP Purge Solenoid Valve 1 Control CKT (Pending) (Old) (Current) (Immature)
[ECM] P0449 - Evaporative Emission (EVAP) Vent Solenoid Control Circuit (SES) (Pending) (Old) (History) (Current) (Immature)
[ECM] P0452 - Fuel Tank Pressure Sensor Circuit Low Voltage (Pending) (Old) (Current) (Immature)
[ECM] P0463 - Fuel Level Sensor Circuit High Voltage (Pending) (Old) (Current) (Immature)
[ECM] P0615 - Starter Relay Control Circuit (Pending) (Old) (History) (Current) (Immature)
will any of these codes keep the injectors from firing?
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
