cam recommendation?
Old Jan 10, 2009 | 01:23 PM
supershift67's Avatar
Default cam recommendation?
I want to get a cam for my stock lq4 engine and put in a 3500 stall. I was just wondering what cam would work good for my chevelle. It is a 67 with headers and 3 inch exhaust. I also am going to run a 4l80e. It has 4.10 gears. If a cam is recommended tell me what else I might need to go with the cam other than programming the ecm. thanks for the help. I would like something I can put in without having to worry about piston to valve clearance.
Old Jan 14, 2009 | 10:38 AM
chevellepowered's Avatar
if u get a cam ur most likely going to have to put in springs.. u might get away using stock springs..depends on how big of a lift.. but do a search ,, u will find out stuff real quick..
