New here thinking about an engine swap
Old Jan 11, 2009 | 02:34 PM
1984 swb chevy's Avatar
Default New here thinking about an engine swap
I have a chance to buy a 2004 vette motor. I would like to install it in my 1984 chevy c10. I have a few questions. Can I use my 700R4 trans? Will I need a different radiator? Any help would be great. Thanks
Old Jan 11, 2009 | 03:22 PM
blk/slvr02ss's Avatar
If you go over to the Hybrid & Conversion section they can help you there,
Old Jan 11, 2009 | 06:53 PM
01ssreda4's Avatar
^^^thats very true. i think the trans will bolt up but the torque converters are different though.
Old Jan 11, 2009 | 08:02 PM
Thank you for your help.
Old Jan 11, 2009 | 09:09 PM
bczee's Avatar
you can use the 700r4.. but will need either a spacer or a dished flex plate. simple solution.
Old Jan 11, 2009 | 09:12 PM
Leevon's Avatar
700R4 will work fine, you will need to get a TV cable kit and use a drive-by-cable throttle body. www.bowtieoverdrives.com has the TV kit, it's about $150. The radiator should work fine, I've seen several of these swaps which used them, and if you're running a clutch fan it will fit nicely.
Edit: VSS signal may be an issue if you have a cable-speedo. There is a conversion unit available from jagsthatrun.com.
Old Jan 12, 2009 | 05:42 PM
jomomma's Avatar
you can definetly reuse your stock radiator. i had to use flex tubing to make it work. if you go with electric fans you can wire them to the pcm so it can turn them on and off .
